  3. How to finish enter functions before form closed?
  • Views 15252
sparksu
sparksu over 17 years ago
I create a form with a button on it. And this button has a callback procedure which invokes enterPoint(). I close my form when enterPoint() is still waiting for responding. An error message about "ilGetString" then appears. How can I finish my button callback before form closed? Any suggestion? Thanks!
    Andrew Beckett over 17 years ago
    I don't believe this should be a problem in general, so there's probably something wrong with your code. Can you post it here so we can see it and diagnose the problem?
  • sparksu
    Andrew, I checked my code again based on your reply. And finally I got the answer. I set a string field value to nil. Thanks very much.
