  3. list substitution problems
  • Views 16212
sparksu
sparksu over 17 years ago
I have a long list here:
listA=list(P1 P2 P3 ... Px-1 Px Px+1 ... Pn)
for a given Px, I want to substitute Px with 2 new elements Px1 Px2  :
ListB=list(P1 P2 P3 ... Px-1 Px1 Px2 Px+1 ... Pn)
I know how to do it using "reverse()" function.
But based on SKILL Language User Guide, reverse() can generate a lot of memeory.
Is there a more efficient way to do this? I don't care if it is destructive or nondestructive.
Here is my code using reverse():
listB2=rplaca(member(Px listA) Px2)                                     ;listB2=>list(Px2 ... Pn)
listB1=reverse(rplaca(member(Px2 reverse(listA) Px1)             ;listB1=>list(P1 P2 P3 ... Px-1 Px1)
listB=append(listB1 listB2)                ;ListB=>list(P1 P2 P3 ... Px-1 Px1 Px2 Px+1 ... Pn)
    Andrew Beckett over 17 years ago
    match=member(Px listA)
    listB=
      if(eq(match listA) then
        constar(Px1 Px2 cdr(listA))
      else
        rplaca(match Px1)
        rplacd(match cons(Px2 cdr(match)))
        listA
    You also should consider whether a list is the right data structure for your needs - I presume whatever you are doing needs to be ordered, otherwise you could have just stuck Px2 on the beginning. Or used a table.
  • sparksu
    Thanks, Andrew.
    Actually, listA is the points of a path object. It should remain their original order.
    Further more, if i want to break listA into 2 seperate sublists
    listA1=list(P1 P2 P3 ... Px-1)
    listA2=list(Px ... Pn)
    What should I do to get listA1 and listA2?
    Can I just break the pointer (or called link) between Px-1 and Px?
    Thanks again for your quick reply.
    Something like this:
    match=nil
    foreach(map rem listA
      when(cadr(rem)==Px match=rem)
    listA2=cdr(match)
    rplacd(match nil)
    listA1=listA
    Note this doesn't handle the case where the match is at the beginning of the list - but that's cheap to check for and handle, as I did in the previous response. Potentially you could make the foreach stop as soon as it finds a match by doing:
    prog(()
        when(cadr(rem)==Px
          match=rem
          return()
    The surrounding prog allows you to use return() to exit the foreach early.
