  3. how to set the scrollbar position in a MLtext field
  • Views 15050
Scott Mcl
Scott Mcl over 17 years ago
In brief we want to programmatically set the vertical scrollbar position in a MLTextField.  Right now the vertical scrollbar is positioned at the bottom of the ML field when the text value is set.
We need a method to set the vertical scrollbar to the top of the MLtext field.
thanks
    Andrew Beckett over 17 years ago
    Use hiSetInsertionPosition(). See Sourcelink Solution 11007015
    Andrew,
