  3. hiShowProgressBar - unable to use...
  • Views 2686
ToMWUT
ToMWUT over 17 years ago
 Hello all,
 I have a very strange problem, I'm trying to use hiShowProgressBar function which is listed in a ui SKILL manual. I'm also able to find it via Finder. But when I try to execute this funcion I get such information:
*Error* eval: undefined function - hiShowProgressBar
My manual coresponds with 5.0 version of Cadence and I'm using 5.10 - so no problem here as well. I'm confused...
 ToM
    Andrew Beckett over 17 years ago
    It's an error in the documentation. The documentation was fixed in an IC5141 hotfix a couple of years ago, so it no longer refers to these functions.
    The functions  are only in ICOA5251 and IC61 onwards.
  • ToMWUT
     Andrew,
    I'm not very familliar with the versions... so is there any possibility for me to use this funcion or some replacement?
     My msfb version: 5.10.41.500.3.49
    ToM
    Well, the ProgressBox functions exist, just not the ProgressBar. They required the changes to Qt which happened in ICOA5251 (and further in IC61). Perhaps you can use those?
  • ToMWUT
    I know Andrew about the hiDisplayProgressBox function and it would do the trick for me, but there is one problem. When I my application opens many ProgressBox'es one after another they are not closed. They are closed when the last ProgressBox closes.
    hiDisplayProgressBox(
    ?name s_name
    [?banner t_banner]
    [?text t_text]
    [?location l_location]
    [?callback g_callback]
    [?totalSteps x_totalSteps]
    [?delay x_delay]
    [?autoClose g_autoClose]
    => t | nil
    And I'm setting the autoClose parameter to true. The problem remains even when I use different names for different ProgresBoxes.
    ToM
    I found a similar report of this from a couple of years ago, and the workaround suggested then was to call  hiCancelProgressBox() when you're done with it. I just tried in the latest hotfix of IC5141 (5.10.41.500.6.136) and I can't reproduce the problem, so I think it's been solved now.
  • ToMWUT
     Worked - thanks :)
    ToM
