  3. Ocean nograph
  • Subscribers 150
  • Views 15739
Ocean nograph
kbhow
kbhow over 17 years ago
 May i know what is the correct way to execute ocean nograph with a replay file.
 Is it
    ocean -nograph OceanScript.ocn
or
    ocean -nograph -replay OceanScript.ocn
    Andrew Beckett over 17 years ago
    The way I always recommend is:to use:
    ocean -restore script.ocn
    Or
    ocean -nograph -restore script.ocn
    There are a couple of benefits of this. One is that because it is like doing a load after starting, you don't see the return value of every single statement in the script, so the output is cleaner. The second is that (compared with redirecting the input to ocean) it will go interactive at the end, so if you've plotted anything the graphs will remain on the screen (assuming you didn't use -nograph !).
    You do need to add a call exit() at the end of the script if you don't want it to go interactive though.
  • kbhow
    Hi Adrew,
    Thanks a lot for the clear explanation.
    How
