  3. How can I return the infomation of components connection...
  • Subscribers 152
  • Views 14977
How can I return the infomation of components connection in schematic file?
jjww
jjww over 17 years ago
Now I want to build a c code description of schematic files. I open one top level schematic file, and get its cellview ID. And I can also return the components within this schematic. Now I want to know the connections of these components so that I can describe it in c code file. So I need the infomation about the output pins and input pins of these components and the wire connections. How can I return the infomation? For example, I open a schematic file describing a PLL, and I get some components like VCO, Lowpass Filter, divider, etc. If LPF's output pins are connected with the input pins of VCO, so how can I get this infomation using some functions?
 Thanks very much for your help!
  • jjww
     At first I tried to find some functions including key words "pin" "netlist" from SKILL Finder. But I failed to find a useful one.
  • Highler
    Highler over 17 years ago
    inspect cv data members, you can find all information from them.
    cv=geGetEditCellView()
    cv->??
    for ex.
    cv->nets~>name
    cv->terminals~>direction
