  3. Custom Parametric Analysis
  • Views 15127
Orcun Kilic
Orcun Kilic over 17 years ago
Hello all,
im trying to use SKILL or ocean script to make a parametric analysis that takes user a defined inclusion list, but mine runs much slower than the one in the Analog Design Environment. Because mine runs a DC simulation for each parameter. But the one in ADE runs only a single DC sim and uses the parameters with that single simulation results. I extracted the script by Save Script command in parametric analysis and when i copy and paste that exact code, it runs very slow because of that problem i mentioned. I consumed myself but cant get anywhere. I would be very glad if some experienced person knows what to do to do it exactly like ADE does. Thanks a bunch!
Orcun Kilic
    Andrew Beckett over 17 years ago
    Please post the generated OCEAN script so we can comment on what the problem is likely to be.
