  3. Virtuoso Analog Distributed Processing Option with SGE
  • Subscribers 150
  • Views 17996
gilberts
gilberts over 16 years ago
I am trying to setup an environment for Virtuoso Analog Distributed Processing Option with SGE (Sun Grid Engine).
We are using IC5141.
The reference manual that I have discuss about setting-up DP with LSF (Load Sharing Facility).
Is there such manual or tutorial on how to setup DP with SGE?
If there is none, does anybody have setup such environment?
Any help would be very much appriciated.
Thank you and best regards,
Gilbert
  • skillUser
    skillUser over 16 years ago
    Hi Gilbert,
    There are a few SGE related solutions on SourceLink, for working with ADE, here are a few that might be useful:
    Solution 11488472
    Solution 11390852
    Solution 11513420
    Solution 11516678
    I hope that at least one of these will be helpful to you.
    Lawrence.
  • gilberts
    Thank you very much, now I am able to use SGE from ADE and from command line via batch file.
    My batch file includes changing of directory and executing spectre.
    example, queue.bat
    cd /home/SGE/test
    spectre simulationFile.spe > simulationFile.log
    Then I will comand;    :/> qsub queue.bat
    In the manual, it discusses about simulating using in "Copy Mode".
    It collects all files on the submitter's host to a temporary directory on the execution host, from where the job is run. The results are written to the this temporary directory and are then copied back to the submitter's run directory.
    Is there a way to simulated like in "Copy Mode" using qsub in command line?
    I think, maybe, it is only applicable in OCEAN.
    About OCEAN, I can not simulate an ocean script when I include.... hostMode( 'distrubuted ).
    I am also trying to use "artbatch" but it seems not for SGE. Is this correct?
    Again, thanks a lot for the help.
    God bless.
    Gilbert
  • gilberts
    Does SGE supports simulation requests from OCEAN?
    I am also trying to use "artbatch" but there is an error.
    Is "artbatch" executable with SGE?
    Have a nice day. :)
    God bless.
    Gilbert
  • amwygah
    amwygah over 13 years ago
     Hi Lawrence.
    skillUser said:
    Solution 11488472
    Solution 11390852
    Solution 11513420
    Solution 11516678
     this url is failure because it will turn to support.cadence.com.
    could you list the equivent url for this web, where it can be accessed.
    I'm sure searching for the numbers on http://support.cadence.com would have found them, but otherwise:
    Solution 11488472 (this is obsolete so no longer on Cadence Online Support)
    Solution 11390852
    Solution 11513420
    Solution 11516678
  • skillUser
    skillUser over 13 years ago
    Thank you Andrew, :-)
    Lawrence.
