  3. How to create a transistor pcell in SKILL?
  • Replies 13
  • Subscribers 153
  • Views 29404
Elezebeth
Elezebeth over 17 years ago
I am new to SKILL coding.I have not done any pcell coding in SKILL.I would like to know whether we can create mosfet pcells using SKILL code.The way I tried to do this is using rodCreateRect( ) to create different layers of the transistor say diffusion,poly,contacts etc.and allign all these layers using rodAlign( ).But the transistor that got created could not be deleted at a time....ie.the layout is flattened.If i select the rectangle that I have set as reference and try to delete the whole transistor layout doesn't get deleted, only that particular layer is deleted.
The other way I found is to do using ?subRectArray.but the problem with that is, the number of contacts in a transistor will increase as the width of the transistor increase.So the number of sub-rectangles that have to be created is variable.How to do that?
Can anybody please guide me on this?
Thanks and Regards,
Elezebeth
    Andrew Beckett over 17 years ago +1
    It sounds as if you're not actually creating a pcell, but just creating level-0 ROD objects. Here's a simple ROD-based example that might get you started: ; ; This pcell demonstrates the use of sub…
    Andrew Beckett over 7 years ago in reply to youcanred
    Hi Jocelyn,
    That is a temporary file used during the pcDefinePCell call. It sounds as if /tmp has run out of disk space - you should check that and maybe clear up some space (lots of things are likely to go wrong in the operating system if /tmp is full anyway).
  • MOHANRAJ A
    MOHANRAJ A over 6 years ago in reply to Andrew Beckett
    Hi Andrew, I tried this transistor pcell code. changed the library name to my library name on both sides,
    But i am getting below warning message,Any idea what kind of error it is ? i tried this code in IC6.1.6
    *WARNING* (TECH-290096): techGetSpacingRule: Layer-purpose pair ("poly") was not defined.
    *WARNING* (TECH-290096): techGetSpacingRule: Layer-purpose pair ("cont") was not defined.
    *WARNING* (TECH-290096): techGetOrderedSpacingRule: Layer-purpose pair ("cont") was not defined.
    *WARNING* (TECH-290096): techGetOrderedSpacingRule: Layer-purpose pair ("poly") was not defined.
    *WARNING* (TECH-290096): techGetOrderedSpacingRule: Layer-purpose pair ("metal1") was not defined.
    Thanks you
    Mohan
    Andrew Beckett over 6 years ago in reply to MOHANRAJ A
    Hi Mohan,
    As I said in my earlier reply (10 months ago) to this old thread from 11 years ago...
    Andrew Beckett said:
    You may also need to edit the layer names in the code too.
    So you'd need to change:
          (polyLayer "poly")
    (diffLayer "pdiff")
    (contLayer "cont")
    (metalLayer "metal1")
    to relevant layer names for your technology.
