  3. How to create a transistor pcell in SKILL?
  • Replies 13
  • Subscribers 153
  • Views 29403
Elezebeth
Elezebeth over 17 years ago
I am new to SKILL coding.I have not done any pcell coding in SKILL.I would like to know whether we can create mosfet pcells using SKILL code.The way I tried to do this is using rodCreateRect( ) to create different layers of the transistor say diffusion,poly,contacts etc.and allign all these layers using rodAlign( ).But the transistor that got created could not be deleted at a time....ie.the layout is flattened.If i select the rectangle that I have set as reference and try to delete the whole transistor layout doesn't get deleted, only that particular layer is deleted.
The other way I found is to do using ?subRectArray.but the problem with that is, the number of contacts in a transistor will increase as the width of the transistor increase.So the number of sub-rectangles that have to be created is variable.How to do that?
Can anybody please guide me on this?
Thanks and Regards,
Elezebeth
    Andrew Beckett over 17 years ago +1
    It sounds as if you're not actually creating a pcell, but just creating level-0 ROD objects. Here's a simple ROD-based example that might get you started: ; ; This pcell demonstrates the use of sub…
    ; This pcell demonstrates the use of sub-rectangles and offset subpaths
    ; in the multipart path transistor implementation. The name of the master
    ; view is:
    ; pcells step8 layout
    ; This pcell accepts these parameters:
    ; width Width of the transistor's active area (note: this is a
    ; distance measured in the Y-direction).
    ; (float, default = 3.0)
    ; length Length of the transistor's active area (note: this is a
    ; distance measured in the X-direction).
    ; (float, default = 0.6)
    ; polyLayer Name of the poly layer.
    ; (string, default = "poly")
    ; diffLayer Name of the diffusion layer.
    ; (string, default = "pdiff")
    ; contLayer Name of the contact layer.
    ; (string, default = "cont")
    ; metalLayer Name of the metal layer.
    ; (string, default = "metal1")
    ; drainName Name of the drain connection.
    ; (string, default = "D")
    ; gateName Name of the gate connection.
    ; (string, default = "G")
    ; sourceName Name of the source connection.
    ; (string, default = "S")
    ; sourceContact Whether source contacts should be included
    ; (boolean, default = t)
    ; drainContact Whether drain contacts should be included
    pcDefinePCell(
    ; Identify the target cellview.
    list(ddGetObj("pcells") "step8" "layout")
    ; Define formal parameter name-value pairs.
    (width 3.0)
    (length 0.6)
    (polyLayer "poly")
    (diffLayer "pdiff")
    (contLayer "cont")
    (metalLayer "metal1")
    (drainName "D")
    (gateName "G")
    (sourceName "S")
    (sourceContact t)
    (drainContact t)
    ; Define the contents of this cellview.
    let((tfId polyExtend contWidth polyContSep diffContEnclose
    metalContEnclose diffPolyEnclose pinEndOffset polySep transObj grid
    polyDiffSep sdWidth)
    ; convert to proper booleans
    sourceContact=(sourceContact==t || sourceContact=="TRUE")
    drainContact=(drainContact==t || drainContact=="TRUE")
    ; Get the technology information for this cell.
    tfId = techGetTechFile(ddGetObj("pcells"))
    ; Get the minimum extension of poly beyond diffusion.
    polyExtend = techGetSpacingRule(tfId "minExtension" polyLayer)
    ; Get the minimum contact width.
    contWidth = techGetSpacingRule(tfId "minWidth" contLayer)
    ; Get the gate spacing
    polySep = techGetSpacingRule(tfId "minSpacing" polyLayer)
    ; Get the minimum poly to contact spacing.
    polyContSep = techGetSpacingRule(tfId "minSpacing" polyLayer contLayer)
    ; Get the minimum poly to diffusion spacing.
    polyDiffSep = techGetSpacingRule(tfId "minSpacing" polyLayer diffLayer)
    ; Get the minimum diffusion enclosure of contact.
    diffContEnclose =
    techGetOrderedSpacingRule(tfId "minEnclosure" diffLayer contLayer)
    ; Get the minimum diffusion enclosure of poly (used when metal contacts
    ; not included)
    diffPolyEnclose =
    techGetOrderedSpacingRule(tfId "minEnclosure" diffLayer polyLayer)
    ; Get the minimum metal enclosure of contact.
    metalContEnclose =
    techGetOrderedSpacingRule(tfId "minEnclosure" metalLayer contLayer)
    ; pin end offset
    pinEndOffset = -(polyExtend + diffContEnclose - metalContEnclose)
    ; source/drain width
    sdWidth = contWidth+polyContSep+diffContEnclose
    ; Get the minimum resolution for this process.
    grid = techGetMfgGridResolution(tfId)
    ; Create the gate and diffusion regions.
    transObj = rodCreatePath(
    ?layer list(polyLayer "drawing")
    ?endType "variable"
    ?width length
    ?pts list(0.0:0.0 0.0:width)
    ?beginExt polyExtend
    ?endExt polyExtend
    ; Define the diffusion region - just under the gate
    ?encSubPath
    setof(arg
    list(
    list(
    ?layer list(diffLayer "drawing")
    ?enclosure 0.0
    ?beginOffset -polyExtend
    ?endOffset -polyExtend
    arg
    ?offsetSubPath
    setof(arg
    list(
    ; Define the drain metal stripe.
    when(drainContact
    list(
    ?layer list(metalLayer "drawing")
    ?pin t
    ?termName drainName
    ?justification "left"
    ?width contWidth + 2.0*metalContEnclose
    ?sep polyContSep - metalContEnclose
    ?beginOffset pinEndOffset
    ?endOffset pinEndOffset
    ; Define the source metal stripe.
    when(sourceContact
    list(
    ?pin t
    ?termName sourceName
    ?justification "right"
    ; Define the diffusion source area
    list(
    ; width depends on whether source contact included or not
    ?width if(sourceContact sdWidth diffPolyEnclose)
    ; Define the diffusion drain area
    list(
    ; width depends on whether drain contact included or not
    ?width if(drainContact sdWidth diffPolyEnclose)
    ; Define the drain diffusion pin. For abut reasons the pin is
    ; the same height that the metal pin is
    ; NOTE - if the difference between diffPolyEnclose and polySep
    ; is greater than the minimum gate length, then when abutted
    ; the drain pin from one transistor can short out the
    ; other transistor. This could be dealt with if necessary by
    ; making the code a bit smarter
    list(
    ?layer list(diffLayer "pin")
    ?pin t
    ?termName drainName
    ; width adjusts to ensure that the diffusion pins will touch
    ; when the devices abut
    ; Define the source diffusion pin. For abut reasons the pin is
    list(
    ?pin t
    arg
    ?subRect
    setof(arg
    list(
    ; Define the drain contact array.
    when(drainContact
    list(
    ?layer list(contLayer "drawing")
    ?sep polyContSep
    ?beginOffset -(polyExtend + diffContEnclose)
    ?endOffset -(polyExtend + diffContEnclose)
    ; Define the source contact array.
    when(sourceContact
    list(
    ?sep polyContSep
    ; Define the gate pins.
    list(
    ?layer list(polyLayer "pin")
    ?pin t
    ?termName gateName
    ?width length
    ?length grid
    ?space width - 2*grid
    arg
    rodCreateRect(
    ?layer contLayer
    ?width 2.0
    ?length 3.0
    ; rodUnNameShape(transObj)
    ; Dimensions for auto-abutment
    ; This is fairly simplistic, and in the case of different sized
    ; devices it can end up with the spacing between gates not quite
    ; as tight as possible in some cases. However, it demonstrates
    ; the principle.
    ; These dimensions are used in the abut function
    pcCellView~>sameWidthDist=-diffPolyEnclose
    pcCellView~>diffWidthDist=polyDiffSep-diffPolyEnclose
    ; Prevent overlap markers
    pcCellView~>lxBlockOverlapCheck=t
    ; Add auto-abutment properties
    foreach(pin dbFindTermByName(pcCellView "S")~>pins
    pin~>fig~>abutFunction="abAbutFunction"
    pin~>fig~>abutAccessDir='("right")
    foreach(pin dbFindTermByName(pcCellView "D")~>pins
    pin~>fig~>abutAccessDir='("left")
  • SkVlsi
    SkVlsi over 13 years ago
    Hi Andrew, I tried this transistor pcell code. its working perfectly after some minor modification related to layer type, however i can see this error in CIW when i load this code. Any idea what kind of error it is ? i tried this code in IC6.1.5 *WARNING* (DB-270534): trigger function: tscSchCheckDbcv is not defined. Regards, Shashikumar Gautam
    This is something in your environment - somebody has called either dbRegPostSaveTrigger or dbRegSaveTrigger (there's a couple of other triggers it might be) and then not defined the function. The function tscSchCheckDbcv is not one of ours - my guess is that the "tsc" might give you a clue - perhaps it is related to a design kit that you're using?
    It's probably harmless, and if you do:
    dbUnregSaveTrigger('tscSchCheckDbcv)
    dbUnregPostSaveTrigger('tscSchCheckDbcv)
    (since I don't know what kind of trigger it is), that should remove the trigger and hence remove the warning.
  • SkVlsi
    Hi Andrew, Thankyou. I did work and there is nor warning now. However may i know what are these trigger? Actually i was using a gpdk45 for creating this pcell. Regards, shashikumar
    They allow you to register a SKILL function to be called when a cellView is saved - one trigger is called before the save and one after the save.
    People use these to implement checks or store additional data at save time.
  • vinayak12
    vinayak12 over 12 years ago
    How to create pulldown menu in the parameter category?
    Vinayak M.
    Create CDF for the cell, and define the particular paramater as a "cyclic" type (Tools->CDF->Edit CDF, making sure you set the CDF type to "Base" so that it gets stored).
  • youcanred
    youcanred over 7 years ago in reply to Andrew Beckett
    Hi Andrew, I tried this transistor pcell code. changed the library name to my library name. But it has
    *error* techGetSpacingRule: argument #1 should be a database object (type template = "dtgg") - nil.
    *Warning* (Tech-2000010): techGetTechFile: Argument must be dbCellViewId or ddId for cell,library,and so forth -nil
    thank you so much!
    regards,
    Jocelyn
    Andrew Beckett over 7 years ago in reply to youcanred
    Jocelyn,
    You would need to change two lines:
    and
    to point to the library you want to create the pcell in - and assuming this is attached (or referencing) the correct technology library. You may also need to edit the layer names in the code too. It will be the second in particular that is causing the errors you're seeing - if there's no library called "pcells" then ddGetObj would return nil, hence the error you are getting.
  • youcanred
    Thank you, i did forget to change the second "pcells".  However, i changed both two parts to my libraray name, it appears another error.
    *Error* drain: port cannot be drained - port:"/tmp/pcGenqc8741"
    Jocelyn
