  3. Converting float number to integer
  • Views 22222
Vignesh054
Vignesh054 over 17 years ago
I have a variable and after calculation it is in the float format. But i want that in integer format.
Eg: i did a=10/3 ; a=3.33
I want to change now the a to 3.
Is this possible?
Please help me.
Vignesh T K
  • kbhow
    kbhow over 17 years ago
    Hi Vignesh,
     Try round(float_number)
    Regards, How
    Andrew Beckett over 17 years ago
    Or floor(). It depends on how you want to do the rounding. There's also ceiling() if you want to round up.
  • skillUser
    skillUser over 17 years ago
    Hi Vignesh,
    Also the fix() function can be used to truncate the fraction
    part. Be aware that fix(3.51) will return 3 but round(3.51)
    will return 4.
    Lawrence.
  • kbhow
    Hi Lawrence,
     I didn't notice that fix() will works on this condition. Cool, i really learn a lot from you and andrew.
     Regards, How
