  3. Creating a Waveform from a Vector or a List
  • Subscribers 152
  • Views 21083
Orcun Kilic
Orcun Kilic over 17 years ago
I would really appreciate it, if someone could tell me how to turn a List or a Vector into a Waveform. I couldnt find anything about it in user references. Thanks!
Orcun
    Andrew Beckett over 17 years ago
    You can use something like the following SKILL code to do this:
    /* abMakeWaveform.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Jul 14, 1999
    Modified   Dec 10, 2007
    By         A.D.Beckett
    A simple function to throw together waveforms for
    test purposes. Usage:
    abMakeWaveform('cos linRg(1 100 1)) => o_waveObj
    Returns a waveform with x axis 1 to 100, in 1 steps, with y
    axis the value of the x.
    A more complex example:
    abMakeWaveform(lambda((x) x*sin(x)) linRg(-40 40 0.1))
    Can be plotted in OCEAN using plot(var).
    Also supports the first argument being a list of y values:
    abMakeWaveform('(5 6 7) '(1 2 3))
    Note the lists must be equal length.
    An optional third argument which is the data type may be supplied,
    e.g. 'double (default) 'single etc. Finally a fourth argument
    may be given if the x-axis wants to be a different type. For example
    for bar graphs:
    abMakeWaveform('(1 -2 4) '("NOM" "SLOW" "FAST") 'double 'string)
    SCCS Info: @(#) abMakeWaveform.il 12/10/07.13:48:06 1.4
    *  DISCLAIMER: The following code is provided for Cadence customers to use at  *
    *   their own risk. The code may require modification to satisfy the           *
    *   requirements of any user. The code and any modifications to the code may   *
    *   not be compatible with current or future versions of Cadence products.     *
    *   THE CODE IS PROVIDED "AS IS" AND WITH NO WARRANTIES, INCLUDING WITHOUT     *
    *   LIMITATION ANY EXPRESS WARRANTIES OR IMPLIED WARRANTIES OF MERCHANTABILITY *
    *   OR FITNESS FOR A PARTICULAR USE.                                           *
    * The generic function takes a function object, or the name of *
    *      a function (a symbol) and calls that function for       *
    *   each of the x values. This would be nice if it could be    *
    *    done as a method, but the problem is that you can only    *
    *   have a method specialised on user defined functions, not   *
    *                      binary functions.                       *
    (defgeneric abMakeWaveform (func xvalues @optional (yDataType 'double)
        xDataType)
      (let (xVec yVec wave)
           (setq wave (drCreateEmptyWaveform))
           (unless xDataType (setq xDataType yDataType))
           (setq xVec (drCreateVec xDataType xvalues))
           (setq yVec (drCreateVec yDataType (mapcar func xvalues)))
           (drPutWaveformXVec wave xVec)
           (drPutWaveformYVec wave yVec)
           wave
    * A method is defined to allow the first argument to be a list, *
    *               and do something different there.               *
    (defmethod abMakeWaveform ((yvalues list) xvalues @optional
        (yDataType 'double) xDataType)
           (when
    	(and (listp xvalues) (equal (length xvalues) (length yvalues)))
    	(setq yVec (drCreateVec yDataType yvalues))
    	wave
  • gilberts
    gilberts over 17 years ago
    Have you tried "awvPlotList" or "artListToWaveform"
    "awvPlotList"
    1. assign variables for list and waveform window
    xlist = list(0 1 2 3 4 5 6 7 8 9 10) ;points for x-axis
    ylist = list(0 1 2 3 4 5 4 3 2 1 0) ;points for y-axis
    win = newWindow()
    2. plot your list with "awvPlotList"
    awvPlotList( win list( ylist ) xlist )
    "artListToWaveform"
    xylist = '( (0 0) (1 1) (2 2) (3 3) (4 2) (5 1) (6 0) ) ;points for xy-axis
    win = newWindow()
    2. convert List to Waveform
    wave=artListToWaveform( xylist )
    3. plot
    awvPlotWaveform( win list( wave ) ?expr list("xylist") )
    I hope this would help.
    Best regards,
    Gilbert
  • Orcun Kilic
     Thanks a lot for the help, it works now. I wish searching cadence help documents was easier
    regards
