  3. A question about dbRegUserTriggers()...?
  • Views 14969
IC Layout
IC Layout over 17 years ago
 Hello Everyone,
                      I have two files f1.il and f2.il .. I would like to load f2.il as soon as f1.il was successfully loaded. Is it possible with the
dbRegUserTriggers() function..?  in cadence IC514 version...
Please, can someone guide me to achieve this....
Prabhakar. K -- Layout Engineer
    Andrew Beckett over 17 years ago
    I assume you meant deRegUserTriggers (there's no function dbRegUserTriggers). Even so, I don't think that's what you want.
    Most likely what you want can be better achieved with "autoloads". The idea is that if you do:
    myFunc1.autoload="f1.il"
    myFunc2.autoload="f2.il"
    Then when you call myFunc1() it will auto-load f1.il (assuming myFunc1 is not defined). The idea is that f1.il should contain the definition of myFunc1 and so on.
    Perhaps that will help you?
