  3. A question regarding CCSchangeCells.il ?
  • Replies 18
  • Views 29737
IC Layout
IC Layout over 17 years ago
 Hai! I found a code which will change cells from one lib/view to another.. in cadence sourcelink ...
I am using cadence IC6X version.. and a IBM(90nm) PDK kit ..
The code is working fine when I tried to convert cells from 'analogLib' to  'gpdk090'..
But when I tried this code in changing cells from 'analogLib' to  'IBM' models it's not happening..
I thought this is because of the following reason.. the IBM PDK kit defines the following params for w(width), l(length), m(multiplier) as
wf(string type),(wff float type), lf(string type), (lfffloat type) and  mpl(int type)...
The params w, l, and m assigned as user defined params after running the code..
I tried to assign the w, l, and m values to the wf, lf and mpl ... the form displaying the values correctly(in schematic).. but when I attempt generate from source it is picking the transistors of default values but the form values remains unchanged.. (in the layout)..
I hope the problem is understandable.... If not I will provide some more information...
Can please some one guide me to achieve this............
Prabhakar. K -- Layout Engineer
    Andrew Beckett over 17 years ago
    You might find the code in this Designer's Guide posting more useful.
  • IC Layout
    Hello, Mr.Andrew,
                            I tried the code .... But only the length param is getting changing, remaining params are still unchanged...
    May be the way I have created the config file  wrong... Is this the way .... Can you please look at it...
      (nil
       fromLib   "analogLib"
       fromCell  "nmos4"
       toLib     "cmos10sf"
       toCell    "dgnfet"
       runCallbacks t
       params (
               ("w" "wt")
               ("l" "lf" )
                ("m" "mpl")
       addProps (
                 ("isnoisy" t)
    abConvertComponentParams("conv.config")
    The same procedure I have followed for changing the cells from analogLib to gpdk090, by modifying the conv.config file as...
      (nil
       fromLib   "analogLib"
       fromCell  "nmos4"
       toLib     "gpdk090"
       toCell    "nmos2v"
       runCallbacks t
       params (
               ("w" "w")
               ("l" "l" )
              ("m" "m")
       addProps (
                 ("isnoisy" t)
    In this case Everything is fine but the finger width(fw) is still showing the default value..
    Can you please, get me out from this chaos......
    Thanks..
    Prabhakar,
    I can't comment on the IBM PDK, because I don't have access to this. But the gpdk090, the problem is that the callbacks are not being called properly. When I tried this, I got these messages:
     *Error* PasCdfGetDpt: argument #1 should be any user-defined (other) type (type template = "o") - abEffCDF@0xb702d88
    (lots of them).
    This is because gpdk uses some type checking, and abInvokeCdfCallbacks needs a slightly different approach. So I updated  abConvertComponentParams.il below. The config can then be as follows (it now allows additional arguments to be passed to the callback calling function - see the runCallbacks part):
      (nil
       fromLib   "analogLib"
       fromCell  "nmos4"
       toLib     "gpdk090"
       toCell    "nmos2v"
       runCallbacks (?useInstCDF t ?callInitProc t)
       params (
               ("w" "w")
               ("l" "l" )
               ("m" "m" )
       addProps (
                 ("isnoisy" t)
    And the updated code is here:
    /* abConvertComponentParams.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Jan 14, 2001
    Modified   May 23, 2005
    By         A.D.Beckett
    Can either convert a single cellView - in the current window:
    Or one in a variable:
    abConvertComponentParams("conv.config" cellView)
    Or one in a variable, not doing the schematic check afterwards:
    abConvertComponentParams("conv.config" cellView nil)
    Or all the matching views in a library
    abConvertComponentParamsForLib("myLib" "schematic" "conv.config")
    Or a whole design hierarchy:
    abConvertComponentParamsHier("conv.config")
    With some different keyword arguments:
    abConvertComponentParamsHier("conv.config" ?cellView cellView
        ?viewList "schematic schem2 symbol"
        ?stopList "symbol" ?check nil)
    (see the code below for details on the arguments to this function)
    Each uses a configuration file which contains the rules for conversion.
    The conversion configuration file contains a single list. Each sub-list
    is a disembodied property list, containing the following properties:
    fromLib:  Name of the library from which the component to
    	  be changed originates
    	  Is an anchored regular expression ("nfet" means "^nfet$"; ".*fet" means
    	  "^.*fet$")
    fromCell: Name of the cell of the component to be changed.
    	  An anchored regular expression.
    fromView: Name of the view of the component to be changed.
    	  Defaults to "symbol" if not specified.
    toLib:    Name of the library in which the new component is
    	  to be found.
    toCell:   Name of the cell of the new component.
    toView:   Name of the view of the new component.
    propMatch:
              An assoc list of property names and values. If the instance
              matches the cell name, and this key exists, it will match if
              all properties match. The property values are treated as anchored
              regular expressions (so "N.*" will match as "^N.*$").
    matchFunction:
              Name of a predicate function (which is passed the instId) to
              decide if this is a match. If neither propMatch nor matchFunction
              keys are provided, it is assumed to match. If both are supplied,
              they must both match.
    runCallbacks: Invoke the callbacks after changes if this is t. If it is
              a list, then these are additional arguments to abInvokeInstCdfCallbacks
    params:   List of parameters to change. Each sub-list contains
    	  two or three elements:
    	    The original parameter name
    	    The new parameter name
    	    [optional] a function to do some modification. The function
    	    will be passed the instance id, the original parameter name,
    	    and the existing parameter value, and will return the
    	    updated parameter value.
    addProps: List of properties to add, or set. Each sub-list contains
    	  two elements:
    	    The name of the property
    	    The value to set.
    An example would be:
      (nil
       fromLib   "analogLib"
       fromCell  "nmos4"
       toLib     "test"
       toCell    "nmos4"
       runCallbacks t
       params (
    	   ("w" "width")
    	   ("l" "length" fixIt)
       addProps (
    	     ("isnoisy" t)
      (nil
       fromLib   "analogLib"
       fromCell  ".*mos4"
       toLib     "test"
       toCell    "pmos4"
       propMatch (("subtype" "pxyz"))
       params (
    	   ("w" "width")
    	   ("l" "length")
    For example, fixIt might be something like:
    procedure(fixIt(inst parName val)
      printf("Fixing %s on %s\n" parName inst~>name)
      ; double the value. Note evalstring is not really a good idea,
      ; just in case the parameter value is some legal SKILL which could do
      ; something unexpected (e.g. "exit()" !)
      sprintf(nil "%n" evalstring(val)*2)
    Unless anything complicated is needed, there is no need to specify a conversion
    function. This may be needed for parameter scaling (e.g. changing from meters to
    microns)
    SCCS Info: @(#) abConvertComponentParams.il 08/19/09.19:03:03 1.8
    *           (abReadConvertComponentParamsConfig configFile)           *
    * Read the configuration parameters for the conversion from the named *
    *                      file, and return the list                      *
    (procedure (abReadConvertComponentParamsConfig configFile)
      (let (prt data)
           (setq prt (infile configFile))
           (while (and (setq data (lineread prt)) (eq data t)) t)
           (car data)
    *      (abConvertComponentParamsPropMatch inst propMatch)      *
    * Check an instance against all the entries in the propMatch,  *
    *                 and return t if it matches.                  *
    (procedure (abConvertComponentParamsPropMatch inst propMatch)
      (let (propVal)
           (forall propPair propMatch
    	       (and (setq propVal (dbGet inst (car propPair)))
    		    (or
    		     (and (stringp propVal)
    			  (rexMatchp (sprintf nil "^%s$" (cadr propPair))
    				     propVal))
    		     (equal (cadr propPair) propVal))
    *                      (abConvertComponentParams                       *
    *                              configFile                              *
    *          @optional (cellView (geGetEditCellView)) (check t)          *
    * Using the conversion configuration information, convert the cellView *
    *                              specified.                              *
    	    configFile
      (let (master config newVal changed newParams)
           ; Read the config file, unless the config parameters were
           ; passed in
           (setq config
    	     (if (stringp configFile)
    		 configFile
           ; Try each component in the config
           (foreach component config
    		; Get the master for the replacement component
    		(setq master
    		      (dbOpenCellViewByType
    		       (getq component toLib)
    		       (getq component toCell)
    		       (or (getq component toView) "symbol")
    		; Fill in the default values in the config
    		(unless (getq component fromView)
    			(putpropq component "symbol" fromView))
    		; Look at all the instances
    		(foreach inst (dbGetq cellView instances)
    			 ; If it matches
    			 (when
    			  (and
    			   (rexMatchp
    			    (sprintf nil "^%s$" (getq component fromLib))
    			    (dbGetq inst libName))
    			   (rexMatchp
    			    (sprintf nil "^%s$" (getq component fromCell))
    			    (dbGetq inst cellName))
    			   (rexMatchp
    			    (sprintf nil "^%s$" (getq component fromView))
    			    (dbGetq inst viewName))
    			   (or (null (getq component propMatch))
    				inst (getq component propMatch)))
    			   (or (null (getq component matchFunction))
    			       (funcall (getq component matchFunction) inst))
    			  (unless changed
    				  (dbReopen cellView "a")
    				  (setq changed t)
    			  ; Initialise the list of new parameters
    			  (setq newParams nil)
    			  ; Then update all the properties
    			  (foreach param (getq component params)
    				   (when (and
    					  (setq newVal (dbGet inst (car param)))
    					  (nequal newVal "")
    					 ; If a function was supplied, call it to
    					 ; process the value
    					 (when (caddr param)
    					       (setq newVal
    						     (funcall (caddr param) inst
    							      (car param) newVal))
    					 ; Delete the old property, and
    					 ; store the new
    					 (dbDeletePropByName inst (car param))
    					 (setq newParams
    					       (cons (list (cadr param) newVal) newParams))
    					 ) ; when
    				   ) ; foreach
    			  ; Update the master to the new component
    			  ; Must do this after changing the parameters, as otherwise
    			  ; getting default values from the CDF doesn't work (since
    			  ; the component changed)
    			  (dbSetq inst master master)
    			  ; Now go through the list of parameters and save them
    			  (foreach param newParams
    				   (dbSet inst (cadr param) (car param))
    				   ) ; foreach
    			  ; Now add any parameters that were asked to be set
    			  (foreach param (getq component addProps)
    				   ) ; foreach
    			  ; If the configuration says to invoke the callbacks,
    			  ; call them
    			  (when (getq component runCallbacks)
    			    (if (listp (getq component runCallbacks))
    			      (apply 'abInvokeInstCdfCallbacks
    				     (cons inst (getq component runCallbacks)))
    			      (abInvokeInstCdfCallbacks inst)
    			  ) ; when
    			 ) ; foreach
    		; Close the master replacement object (for tidiness)
    		(dbClose master)
    		) ; foreach
           ; If anything changed, need to save it
           (when changed
    	     (when check (schCheck cellView))
    	     (dbSave cellView)
           ; Let the caller know if anything got changed
           changed
    *    (abConvertComponentParamsForLib libName viewName configFile [check])    *
    * Convert all cells in the library libName which have a view viewName, using *
    *                     the configuration file passed in.                      *
    (procedure (abConvertComponentParamsForLib libName viewName configFile
    					   @optional (check t)
      (let (config cellName cellView)
           ; passed in
           (setq config
    		 configFile
           (foreach cell (getq (ddGetObj libName) cells)
    		(setq cellName (getq cell name))
    		(when (ddGetObj libName cellName viewName)
    		      (setq cellView
    			     libName cellName viewName))
    		      (when cellView
    			    (printf "Converting %s/%s/%s\n" libName cellName viewName)
    			    (abConvertComponentParams config cellView check)
    			    (dbClose cellView)
      t
    *                   (abConvertComponentParamsHier                    *
    *             configFile [?cellView (geGetEditCellView)]             *
    *              [?viewList "schematic cmos.sch symbol"]               *
    *                        [?stopList "symbol"]                        *
    *                             [?check t]                             *
    *                          [?visited table]                          *
    * Traverse the design hierarchically, using the specified view list  *
    * and stop list, converting the parameters as outlined in the config *
    * file supplied. The ?visited argument is only intended to be passed *
    *  when this function is called recursively - end users should not   *
    *  pass this argument. ?check allows you to turn off the check done  *
    *  before saving. The default cellView to start from is the one in   *
    *                        the current window.                         *
    (procedure (abConvertComponentParamsHier
    	    configFile @key (cellView (geGetEditCellView))
    	    (viewList "schematic cmos.sch symbol")
    	    (stopList "symbol")
    	    (check t)
    	    (visited (makeTable 'visited nil))
      (let (config switchedView)
           ; passed in
           (setq config
    		 configFile
           ; Convert the stop list to a list for convenience
           (when (stringp stopList)
    	     (setq stopList (parseString stopList)))
           ; Convert the parameters for this cellView
           ; Traverse the hierarchy
           (foreach header (dbGetq cellView instHeaders)
    		; Switch into a cellView in the view list
    		(setq switchedView (dbGetAnyInstSwitchMaster
    				    (car (dbGetq header instances))
    				    viewList))
    		(when switchedView
    		      ; Unless I've been here before, or it's a pcell,
    		      ; or it's in the stop list, then recursively call
    		      ; this function
    		      (unless
    		       (or
    			(arrayref visited switchedView)
    			(dbGetq switchedView isParamCell)
    			(dbGetq switchedView superMaster)
    			(member (dbGetq switchedView viewName) stopList)
    		       (setarray visited switchedView t)
    			config
    			?cellView switchedView
    			?viewList viewList
    			?stopList stopList
    			?check check
    			?visited visited
    		       ) ; unless
    		      ) ; when
    		) ; foreach
           t
           ) ; let
      ) ; procedure
  • IC Layout
     Hi, Mr. Andrew,
                              I really very thankful to your kind response... I tried your updated code, it is working fine when changing cells of  'analogLib' to 'gpdk090' ... I don't know what's the problem with IBM PDK kit... After some trials atlast I got the solution ... it may not be that much efficient code as you have written... But this is a possible solution for me.......
    For every cell of analogLib, I am storing the respective (w, l, m, xy, orient) params and then I have created an instance of IBM model in that place by assigning the stored params( to the respective cell attributes) & then deleting the old one...
    And finally, I am running your code  like this " abInvokeInstCdfCallbacks(geGetEditCellView()) " ... And my custom gen4msource.il code is doing its job perfectly........
    Thank you very much once again............
  • ebecheto
    ebecheto over 14 years ago
    Hi Andrew.
    I continue this post, because it is related. I launched it, but I faced a trouble shoot due to the wrong/annoying behaviour of the DesignKit.
    Indeed, there callbacks launch a popup that block the automatic execusion. Some instances have wrong values. I know, since I want to change from a former techno to a new one. For instance, a capacitance Length=30u; Width=1u. Results in
    Limits Exceeded : Design Rule limite beyond minimum limit 4.0u
    Limits Exceeded: Aspect ratio = 0.13, Parameters outside valid range. Valid aspect ratio is 0.33< w/l< 3.0 Valid area (w*l)<=10,000sq-um
    Anyway, it is not your sript fault. If I selectedone of the 'trouble' capacitance and I launch :
    evalstring(cdfFindParamByName( cdfGetInstCDF(css()) "w")->callback) ;<=> evalstring("cmhv7sfmimWidth()")
    I definitely got the 'nasty' popUp ...
    I can't interactively validate it by skill with some kind of hiDBoxOK(limitsWarningMsg) functions, since CIW  freeze due to the popUp.
    Do you have any idea on how to prevent popup or auto validate them ? I want to get trough it whatever the value of the capacitance will become.
    Thank in advance for any clue.
    PS: I had to click a bazilion time to get trough CCSCdfCallbackEntireLib("MYLIB")..
    You might be able to use hiRegTimer() to schedule a delayed invocation of the hiDBoxOK() call - but you'd have to call it just in case - exactly what you call would depend on the actual dialog box that gets launched. At least I think that might work...
    Alternatively contact the Design Kit provider and see if they have a switch to disable their dialog boxes? Unfortunately it's a sign of a badly designed PDK if it does this - but maybe they have catered for automated invocation of the callbacks.
  • pychou
    pychou over 12 years ago
    I am now using the 2006 version of alInvokeCdfCallbacks.il.
    I just solved the following problem by one of you posts:
    *Error* PasCdfFormInit: argument #1 should be any user-defined (other) type (type template = "o")
    /forums/p/17081/1181192.aspx
    I call the function like the way you wrote: abInvokeCdfCallbacks(cvId ?callInitProc t ?useInstCDF t)
    Now I use the gpdk045 library.
    There is no problem when I set the properties of a transistor and call abInvokeCallbacks.
    However, when I try to do the same thing to a capacitor, it displays the following:
    *Error* PasCdfSetValue: argument #1 should be any user-defined (other) type (type template = "ogg") - nil
    Do you have any idea how to get rid of this error?
    Thanks in advance!
    If you could provide me with the following information:
    1. The "SCCS Info:" line near the top of the code - this gives me the precise version number so I can revert back to it if needed to try it out.
    2. Which capacitor from gpdk045 are you using?
    3. Ideally if you could tell me the component parameters and values you've set on this
    4. And which version of gpdk045 (I doubt it makes a difference though).
  • pychou
    Thanks for your reply!
    Here is the information.
    1. SCCS Info: @(#) abInvokeCdfCallbacks.il 06/07/07.14:29:59 1.11
    2. nmoscap1v
    3. dbReplaceProp was used to set the parameters:
    c=1.508p, fw=10u, l=10u, m=2, simW=120, w=10u
    By the way, a warning kept showing up:
    *WARNING* (DB-270000): dbReplaceProp: Datatype for input parameter 'fw' does not match the definition
    and it showed same warning for 'l'
    That line is like dbReplaceProp( cv "fw" "string" "10u" ).
    4. v3.5
    It appears to be a bug with the callbacks for that device for some parameters. It's nothing to do with the version of my code. If I interactively place an instance of that device and change any of:
    • Gate Connection (connectGates)
    • S/D Connection (connectSD)
    • Bodytie Type
    • Left Tap (leftTap)
    • Right Tap (rightTap)
    and a couple of others too, I get the same error.
    You should be able to solve this by passing the ?order argument to limit which callbacks get invoked. It's OK to pick parameters that aren't on all devices - so something like:
    abInvokeCdfCallbacks(cv ?callInitProc t ?useInstCDF t ?order list("w" "l" "fingers"))
    (you'll need to do some checks to find an appropriate set of parameters to trigger the callbacks across all your devices, and pick an appropriate order).
    The warning message is because you are presumably placing the device in a layout, and in this PDK the pcell parameters are floats rather than strings. On the schematic, they're strings, but on the layout they're floats.
    Hope that helps.
