  3. How to flatten cell in non-graph mode
  • Views 19985
sparksu
sparksu over 16 years ago
 I want to flatten a hierarchial layout cell.
leHiFlatten() can do this in graph mode.
But compared to leHiFlatten(), it is extremely slow to do this by using dbFlatInst() in non-graph mode.
Is there an alternative way to flatten a database in non-graph mode?
Thanks.
    I'd be surprised if dbFlattenInst is any slower than leFlattenInst (which is used within leHiFlattenInst) since I believe the code is the same.
    Are you sure you're giving it the same arguments?
    This should be a pretty efficient way of doing a flatten. I don't know of a more efficient way.
  • sparksu
    Thanks. I got it.
    Here is my code.
    cv=deGetCellView()
    objs=cv->instances
    foreach(obj objs
           when(obj->objType=="inst" dbFlattenInst(obj 32 t))
    );end foreach
    Since  dbFlattenInst() and leHiFlattenInst() are of the same code, It must be "foreach"  who made my code slow.
    "objs" is too large to be traversed.
    Really? If there are that many instances that the foreach is slow, then probably you're going to end up witha huge flat cellview, and that's more likely to be the problem.
    What does length(objs) show?
  • sparksu
    Sorry. I can not get my original code now. I'd like to post my entire code here later.
  • sparksu
    You are right, Andrew.
    Traversing objs did not make my code slow.
     length(objs)=>480
    I compared the following codes:
    ;Code A
    foreach(obj objs
    when(obj->objType=="inst" dbFlattenInst(obj 32 t) )
    ;end foreach
    ;Code B
    foreach(obj objs
    when(obj->objType=="inst" dbFlattenInst(obj 32 t nil t) ) ;preserveRODobjs
    );end foreach
    Code A cost 120 seconds.
    Code B is too slow to be finished. I waited about 0.5 hours and then killed it manually.
    I think it is the argument "preserveRODobjs" who made my code slow.
