  3. Need a way to verify schematic vs schematic ..?
  • Views 16776
IC Layout
IC Layout over 16 years ago
 Hi! I am using IC514 version of cadence.
I am converting schematics from one technology to another ...(tsmc45 -- to -- tsmc65)
I have converted all the cells which corresponds to tsmc45 to tsmc65 ...
Now I would like to know whether the properties of converted cells still same as in tsmc45 or not..?
Means, I need a kind of SVS (schematic vs schematic) checker in SKILL.
I need to check only the proerties which are displayed in the form.
The problem that I am getting in comparing the properties is with the form type..
The two forms are (ex: for a nch_25 cell ) not identical..
Is there anyway to resolve this problem..?
Thanks in advance.
Prabhakar. K -- Layout Engineer
    You could just use an LVS program to do this, such as Assura or Diva. Both can be used to do SVS comparisons.
