  3. Toolbox Bindkey
  • Views 15631
Toolbox Bindkey
kashvi
kashvi over 16 years ago
Where can I find toolbox bindkeys in virtuoso 6.1.3 version?
How the normal bindkeys works during Toolbox is 'ON' ?
-K
  • kbhow
    kbhow over 16 years ago
    Hi Kashri,
    There is a document with name toolboxhelp.pdf at your installation directory. You can get more infomation about TTB bindkeys.
    TTB bindkeys work as normal bindkeys. You just need to hit the key to call out the functions.
    How
  • kashvi
     Hi How,
    Can you please let me know the toolbox function name to define a bindkey.
    I want to toggle toolbox ON/OFF.
    -K
  • kbhow
    Hi Kashvi,
    Sory for the late reply, i was busy lately. You are able to see the TTB function name in CIW. To make it visible to user, at CIW, go to Options->Log Filter and check the option for "Accelerated input ( menu and bindkeys commands, form and field value setting and callbacks, etc)".
    After the option is checked, any function that you use in cellview will be display in CIW. For example, turbo ruler. The command show in CIW is _leTbCommand("_leTbRuler(nil nil t)" t). You can set the bindkeys as below:
    hiSetBindKey("Layout" "<Key>k" "_leTbCommand(\"_leTbRuler(nil nil t)\" t). ")
    ** Please bear in mind that the TTB function only applicable when TTB is activated.
    How
