  3. Global library with layout view which able to use in all...
  • Subscribers 150
  • Views 16960
Global library with layout view which able to use in all processes
kbhow
kbhow over 17 years ago
Is it possible to construct a global library with layout view which able to use in all processes? If yes, do you mind providing the proper way to do that. Thanks
BTW, Noticed that each process has their own techFile and layer mapping as well, if we create the layout in particular process, the layout will not able to work on other process due to imcompatible data.
Your advice/suggestion is very appreciated.
How
  • kbhow
    Hi all,
    I think i found the solution for this. To create a library which able to use globally, we can use incremental techFile method. We can create a new library and techFile.tf that contains layers that use in the layout and load it, then save it as tech.db. The layer names and numbers in the techFile.tf cannot be the same as other techfiles. Otherwise it will lead to errors during techfile compilaton.
    Then, in the main tech file, add global library to refTechLibs eg: refTechLibs("cs1234" "globLibrary")
    For all other processes, you can now simply add "globLib" in refTechLibs and the library "glodLib" in cds.lib to ensure that users can make use of the rdt cells. This is basically the concept of incremental techfiles.
    How
  • Austin CAD Guy
    Austin CAD Guy over 17 years ago
     Hi How
     You are creating an independent library which does not collide with the existing techLib definitions. You may have to map the additional layers in the ITDB library to the layers in your process techLib using a layerMap file for GDS and equivalent layers for the tools. This leaves open many potential areas of error.
    If the devices are not complex, you could represent them as pcells with the layers and possibly the rules defined from the existing techLib. Each placement would be custom for the design. Use dbWriteSkill to get the initial SKILL which you would have ot parameterize with layer names, etc.
    You can also use the mapper capability to take an original library and map it to a specific technology. Copy the original library, set up the mapping table (once per technology) and it will change the layers to the ones in the techLib. You will now have a copy of the original library in the new technology. This is probably the safest methodology.
     Ted
  • kbhow
    Hi Ted,
    Thanks for the info. I use to create an original library and map it to a specific technology, where this techFile is created with layer defination only. Can this work too?
    How
