  3. toolbox function
  • Views 14773
toolbox function
kashvi
kashvi over 16 years ago
 How can I turn toolbox ON/OFF using same bindkey?
-K
  • kbhow
    kbhow over 16 years ago
    Hi Kashvi,
     Ya, you can do that, but from my perspective, i don't think this is a very practical way to enable/disable TTB using bindkey. And since TTB is enble using form, it will facing some difficulty in dealing with the form. Maybe other expert can help on this :-)
    I create a simple skill code for this, you can have try.
    procedure( howEnableTTB()
        if( boundp('TTBForm) then   ;read global variable for TTB form
            if( TTBForm && TTBForm->_formName == "Toolbox Options" then
                if( TTBForm->leTbEnableToolbox->value
                    TTBForm->leTbEnableToolbox->value = nil
                    TTBForm->leTbEnableToolbox->value = t
                );if
                hiFormDone(TTBForm)
            else
                    leHiEditTbOptions()                    ;Instantiate the form for 1st time
                    TTBForm = hiGetCurrentForm()
                );if
            else
                leHiEditTbOptions()                   ; Instantiate the form for 1st time
            );if
    );proc
    hiSetBindKey("Layout" "<Key>a" "howEnableTTB")
    Noted: This script needs user to at least instantiate the TTB option's form once in order for the code to works. This is the quick code, i will try to find the better one :P (Beware that the is possible the TTB/other bindkeys will overide the bindkey)
    How
