  3. OCEAN simulation script in DP with SGE
  • Views 15085
gilberts
gilberts over 16 years ago
Can I simulate an OCEAN script using Distributed Processing (DP) Option with Sun Grid Engine(SGE)?
Using DP with SGE, I was able to queue simulation from ADE.
I was also able to queue shell batch files to simulate spectre netlists, using "qsub".
With OCEAN scripts, I can not simulate an ocean script when I include....
hostMode( 'distrubuted )
Does SGE supports simulation requests from OCEAN?
I am also trying to use "artbatch" but there is an error.
Is "artbatch" executable with SGE?
Have a nice day. :)
God bless.
Gilbert
    SGE is supported from both ADE and OCEAN (essentially it's the same - if it works in ADE it should work in OCEAN).
    You give no information as to what doesn't work - i.e. were there any error messages? What exactly happens when you try to use hostMode('distributed) in your OCEAN script?
