  3. Apply envSetVal to current window
  • Views 16108
stuso
stuso over 16 years ago
Hi all,
I'd like to create a skill procedure to implement:
envSetVal( "layout" "displayStretchHandles" 'boolean t )
it seems that i need  to apply this to the current window, so i guess i need to use:
geGetWindowCellView()
I'm wondering how do i apply my env setting to a particular window?
I'm assuming the windiow will be the current layout window as i'll eventually be adding the procedure to a drop down menu, therefore you'd need to have clicked in said window therefore making it the current window.
Stu
  • stuso
     I've just noticed that entering:
    envSetVal( "layout" "displayStretchHandles" 'boolean t)
    does seem to  then turn on stretch handles to any new layouts opened from that point on.
    Stu,
    hiGetCurrentWindow()~>displayStretchHandles=t
    Does what you want. Essentially these display cdsenv vars are used to seed window properties when you open a new window.
  • stuso
     Hi Andrew, thanks thats great.
