  3. How to change the DFMoptions for a pcell using skill
  • Subscribers 152
  • Views 15388
VEERA PRAMOD
VEERA PRAMOD over 16 years ago
Hi all..
  I am using TSMC 65nm library.I have to set DFMoptions as DFM+Analog for the pcells.How should i change the DFMoptions to DFM+Analog in pcell.I used the dbSetq(geGetSelSet "DFM+Analog" "DFM_options") for this command output of CIW is ("DFM+Analog").But he property is not changing.If U know please give me solution.
Thank you.
Veera.K Pramod
  • IC Layout
    IC Layout over 16 years ago
     The part of solution lies in the below line..
    geGetSelSet()~>DFM_options="DFM+Analog"
    But this event will not triggered by the corresponding callback...You need to run callbacks to see the changes...
    I hope this can be understandable..
    As has come up before, sourcelink solution 11018344 covers how to do this (call the callbacks). I recently updated the solution to reflect the latest version of my code.
