  3. Skill code to toggle EIP (Edit in place)
  • Replies 10
  • Views 20152
zeroskills
zeroskills over 16 years ago
Hi All,
I always use EIP (edit in place) and would like to have a toggle to turn it off and on, could you help me with a skill code. I would like to assign it to a bindkey - "alt+x". pressing "alt+x" will turn on or off EIP.
Thanks.
  • dmay
    dmay over 16 years ago
    I'm assuming you are talking about the EIP surround option on the Display Options form. If so, then this is all you need:
    procedure(toggleEipSurround()
        let(((win hiGetCurrentWindow()))
           if(win->drawSurroundingOn
                win->drawSurroundingOn=nil
                win->drawSurroundingOn=t
        ) ;let
    ) ;proc
  • zeroskills
    That was quick. was it a default skill code or it was just that easy?
    Anyway, Thanks for help.
  • skillUser
    skillUser over 16 years ago
    I will add to what Derek said.  If you are talking about the default "x" bindkey which performs Edit-In-Place, then the default Shift-B bindkey should perform a return operation.
    Lawrence.
    Hi zeroskills,
    What does "turning EIP on or off" mean? Edit in Place is an action you take - you edit in place, select a location, and it descends to that point. I don't see that there's anything to turn on or off?
    Perhaps you mean toggling the display of the EIP surround? (As on the Options->Display form). If so, the trick would be to look at:
    hiGetCurrentWindow()~>?
    Figure out the relevant property name (I can't check because I'm sending this from a PDA in an airport), and then your bindkey would be:
    hiGetCurrentWindow()~>thePropName=!hiGetCurrentWindow()~>thePropName
    Where "thePropName" is whatever it is called.
    But of course this is guesswork - you may be asking a different question!
    Thanks to Derek for identifying the property name (my previous reply explained how to figure it out yourself).
    That said, defining a function is overkill for this, as:
    hiGetCurrentWindow()~>drawSurroundingOn=!hiGetCurrentWindow()~>drawSurroundingOn
    Would be sufficient.
  • zeroskills
    Derek's code is all i need, just toggling EIP from on to off and vice versa. i had a similar one but the if statement is a hit and miss, and there's a condition to satisfy like if M0 drawing is present, do the EIP - off else -on.
    But the code above is fine.
    Thanks for the help.
    What do you mean by "default SKILL code?"
  • zeroskills
    Hi Andrew ,
    is  this what you meant?
    procedure(drawSurroundingOn()
    ) ;proc
    hiSetBindKey( "Layout" "Alt<Key>c" "drawSurroundingOn()")
    i thought there's a default skill code for toggling edit in place (eip). my current skill code wasn't working properly so i have to do it in the display option's window (e)
    Sort of, but you don't really need to define the procedure. Just doing this would be enough:
    hiSetBindKey( "Layout" "Alt<Key>c" "hiGetCurrentWindow()~>drawSurroundingOn=!hiGetCurrentWindow()~>drawSurroundingOn")
    There's no built in function to do this toggling (if that's what you meant by "default") because it's such a simple expression to do it.
  • zeroskills
    I guess you're right, since i had a skill code for it so there wasn't a really a default one in the first place. i was just checking in case there was and didn't even knew it.
    Thanks for all you're codes and helping me again.
