  3. A question about schematic 'descendTarget' ?
  • Subscribers 152
  • Views 6106
IC Layout
IC Layout over 16 years ago
 Hi! All,
           I am using cadence IC514 version.. I got some schematics from my designers .. In those schematics the descend target query selection cyclic showing the first member as " symbol " instead of " schematic " ..
How to get the first member as "schematic" in the query selection field..?
I tried the following .. this is also not working.
schSetEnv("descendTarget" list("schematic" "layout" "symbol"))
Can someone guide me in this way..
Thanks & Regards
Prabhakar. K -- Layout Engineer
  • sunilkumar
    sunilkumar over 16 years ago
    Prabhakar,
    In the schematic window, you can change this list in the menu Options->Editor->Commands View Name list. You can add this change in .cdsenv
     If you  want to set using schSetEnv,  you can try
        schSetEnv("viewNameList" "schematic symbol")
     Sunil
