  3. Select nets in schematic.
  • Views 17761
marbs
marbs over 16 years ago
How can I select net in schematic by using skill ?
and report all its connections ?
Thanks in advance.
    Something like this:
    netName="iref"
    cv=geGetEditCellView()
    net=dbFindNetByName(cv netName)
    ; select all the wire segments on the net
    foreach(fig net~>figs geSelectFig(fig))
    ; print connections
    printf("Net %s is connected to:\n" netName)
    foreach(instTerm net~>instTerms
      printf("  Pin %s of instance %s (cell %s)\n"
        instTerm~>name instTerm~>inst~>name instTerm~>inst~>cellName
    Best Regards,
  • marbs
    Than you very much for the code sir, sorry for the late reply.
    But I've got an error when I run the code,  something like this :
    *Error* eval : unbound variable - netName .
    Please complete the code.
    Thank you .
    Er, the first line of the code sets netName, so presumably you didn't cut and paste it, or omitted that part and didn't set it yourself...
    Of course "iref" is not necessarily the name you want.
    You could of course change it to be a function definition:
    procedure(CCSselectNet(netName)
    let((cv net)
      ; print connections
    And then use:
    CCSselectNet("myNet")
  • marbs
    The code is excellent,
    It is now running.  Thank you very much sir.
