  3. How to add the unit of u to a whole lib cells and replace...
  • Views 15670
How to add the unit of u to a whole lib cells and replace the cells by an other lib??
skillstudy
skillstudy over 16 years ago
I have a database which has no the unit of u for the mos size. Now I want to add the unit of u to this lib and replace the cells of this lib with an other lib cells. How to do with skill script? Please help me. Thank you!
  • skillstudy
      I have found a old answer for change cell from new lib:
      master=dbOpenCellViewByType("NEW_PROCESS" inst~>cellName inst~>viewName)
    inst~>master=master
       but how to change the mos size? such as a mos size is 2/0.12, how can i change it to 2u/0.12u?
       Thank you!
    A similar question has come up in a previous post. Be sure to use the code in that post, together with the abInvokeCdfCallbacks code from the original code on the Designer's Guide site.
  • skillstudy
    Thank you very much!!
