  3. ROD example
  • Views 16481
ROD example
sprinter
sprinter over 16 years ago
I'm trying to generate a transformer pcell using ROD. Has anyone done a similar pcell using ROD which you can share?
Adil
  • skillUser
    skillUser over 16 years ago
     By "transformer" are you talking about a layout which has overlapping or adjacent coils, such as those for an inductor? Could you use an inductor as a starting point for this?  There is Solution 1809475 on SourceLink for a Spiral Inductor.
    Oh, while I was looking at that Solution, I noticed that it points to examples in the software hierarchy, and I see that there is a transformer PCell there:
    `cds_root icfb`/tools/dfII/samples/artist/passiveLib/transformer/transformer.s.pc
    Hope this helps you!
    Lawrence.
