  3. SKILL arithmetic comparisons
  • Views 18372
sri125
sri125 over 16 years ago
 SKILL is notorious for the way it stores numbers in memory. e.g variable w, which
should be 0.4 gets stored as 0.3999999999999 or something like that.
So when you use it in 'if-else' loop like:
if( w == 0.4 then
    block good;
else
   block bad;
You will end up in block bad unless you do something like
abs( w - 0.4 ) < 0.000001
or something like above.
Is there an elegant way to handle this in SKILL ?
thanks
  • skillUser
    skillUser over 16 years ago
    There is nothing "notorious" or special with the way that SKILL stores floating point numbers compared to other programming languages.  A floating point number is typically stored in an IEEE (754) format which is comprised of a sign, an exponent and a mantissa (or significand).  Most decimal numbers do not have an exact representation in the binary floating-point storage format used in single-precision and double-precision data types.  So in order to be able to test for equality in a reliable fashion, the best thing is to subtract one number from the other and test the remainder against a small number, exactly as you have shown.  The small number could be a fraction of the input number so that the test works equally well for large values and smaller values.
    Sorry, that's just how things are for floating point number comparison, I'm not sure if there is any better way?
    Lawrence.
    As Lawrence says, you get exactly the same kind of rounding errors in C and all languages using IEEE floating point numbers. In fact whenever this comes up with someone saying this is a bug in SKILL, I show a C program with the same behaviour.
    The trick is to write a function to do floating point "equality" checks. If you know the magnitude of the numbers, you can use a fixed size "epsilon" as in your example.
    Or you can do something like:
    procedure(myCompare(a b @key (reltol 1e-6) (abstol 1e-12))
    let((tol)
    tol=reltol*max(abs(a) abs(b))+abstol
    abs(a-b) < tol
    This has both a relative and absolute tolerance in the comparison.
  • sri125
     Thanks Lawresce and Andrew.
