  3. Checking existance passed variables
  • Subscribers 150
  • Views 17118
markbeck
markbeck over 16 years ago
If I have a procedure:
procedure( foo( @key (x1 nil) )
And inside it I want to check to see if the key x1 was ever passed in, how would I do that?
I would want the behavior of:
foo()
to be different than
foo(?x1 nil)
So what I need to check is whether x1 was passed in, not whether x1 == nil.
Any ideas?
Mark
  • markbeck
     A local skill guru helped me out.
     To check the existance of a variable being passed in, you just need to specify the variable as 'unbound and use a boundp check internally.
     e.g.
    procedure( foo( @key (x1 'unbound))
       if(boundp(x1) then
       ); if
    ) ; procedure
    One way is to do:
    procedure( foo( @key (x1 'unbound) )
    when(boundp('x1)
    ; it was passed in
