  3. Skill code for LSW form
  • Subscribers 152
  • Views 15538
zeroskills
zeroskills over 16 years ago
We don't have this currently available to us. but from my previous work, we have it.
The LSW form stores whatever your setting on your LSW window, and it can restore it as well, it can store up to 6 or more settings depending on the coding.
For example:
- i have all selectable all visible ---> setting 1
- metal 1,2,3 via 1,2,3, label 1,2,3 are selectable, the rest is unselectable --->setting 2
So i can call the form, and i can switch from setting 1 and 2 and can add other setting as well.
  • skillUser
    skillUser over 16 years ago
    There is an existing SourceLink solution 11270216 which may help with what you want to do, the solution creates a bindkey for loading a LSW Layer Set file. You could write a SKILL form to have a couple of buttons and load the appropriate file depending on which button was pressed.  Is that the sort of things that you are asking for?
    Lawrence.
  • sri125
    sri125 over 16 years ago
     Lawrence,
    What is the format of the layers file ?
    thanks
  • sri125
     Oops, did not read the full solution. Got it.
