  3. problem in running IC610 (CADENCE),showing skill errors
  • Replies 9
  • Subscribers 152
  • Views 8917
Bhavsh
Bhavsh over 16 years ago
Recently i installed IC610 (cadence) in Redhat linux,but while running "icfb" i am getting many errors.When i give the comand "icfb" ,CIW opens but in between it ask for :"(delicense-7) couldnt get a license for schematics L.would you like to try to get a higherr tiered license to run this product?....(yes)..(no)..(always)..(never).."
By clicking any options,it process for some time and end up in giving the error..
The warnings and errors which is showing are--
" *WARNING* Cannot find /cad/cadence/ic6/tools.lnx86/dfII/etc/tools/cdsSpice directory to load environment variables
*WARNING* envSetVal: could not find tool[.partition] 'layoutOptimize.state'
loading vars from /home/vinaymm/cad_work/cadence_design/ncsu-cdk-1.5.1/cdssetup/cdsenv for tool layoutOptimize
loading vars from ~/.cdsenv for tool layoutOptimize
loading vars from ~/.cdsenv for tool asimenv
*WARNING* (icLic-3) Could not get license Virtuoso_Schematic_Editor_L
*WARNING* (icLic-3) Could not get license Virtuoso_Schematic_Editor_XL
Loading awv.cxt
*WARNING* There were no system .cdsplotinit files found.
Loading NCSU SKILL routines...
Loading oasis.cxt
ERROR (ADE-5066): Tool 'spectreS' has not been registered.
ERROR (ADE-5067): Unable to initialize tool 'spectreS'; either tool class is not
defined or tool is not registered.
*Error* The default SKILL generic function has not been defined for the function "asiEnvGetVar". Ensure that this function is called with the correct argument(s) (tool partition name).
But its nt giving any license error for IC5141.  pl checkout the attachment in which information in the CIW is copied..
How can i solve this problem...pl reply soon..
Thank you,
Back to top
IC61_ERROR.doc
    The problems probably all stem from having an old .cdsinit or .cdsenv file.
    The first is probably because there's some SKILL code in there which is trying to invoke some schematic function, which is causing it to try to check out a license. If it can't get either Virtuoso_Schematic_Editor_L or XL licenses, then the chances are your licenses have not been updated to reflect the new products.
    cdsSpice, spectreS and hspiceS are no more - hence errors for those - but these would probably only appear if there are some envLoadVals() calls or envLoadFile() calls in your .cdsinit. And some out of date .cdsenv files.
    That appears to be the major problem you're seeing. I can't open the doc you uploaded (for some reason, the web site is giving an error), so I'm not sure precisely which version you're using - hopefully it will be an IC613 hotfix, because IC610 itself is not recommended or even supported any more. Not that these errors have anything to do with that.
    You could try running "virtuoso -nocdsinit" to see how that behaves...
  • Bhavsh
     I am using IC 610 ...Here i am sending you the attachment again..
    While creating library also its showing some errors.
    Errors are -
    *Error* eval: undefined function - libManCreateLib
    <<< Stack Trace >>>
    libManCreateLib("cdkCreateNewLib" "analogLib" "MOS_a2d" "ams" "" ... )
    (... in ddsiLMCEval ...)
    (... in ddsLMCMenuItem ...)
    ddsLMCMenuItem(1 "cdkCreateNewLib" "libManCreateLib" ("analogLib" "MOS_a2d" "ams" "" ""))"
    This is also bcz of same prob??
    IC61_ERROR.doc
  • skillUser
    skillUser over 16 years ago
     I cannot download the attachment to view it.  However, it appears that the above messages are due to Library Manager customization (in a cdsLibMgr.il file) which probably redefines the Create New Lib function to call the "libManCreateLib" function which needs to be defined in the DFII (Virtuoso) session.  Since I cannot see the other messages I will not speculate any further than this.
    Lawrence.
  • Bhavsh
    This attachment will open.. I checked it..I am sorry for the above 1's.
    IC61_ERROR.zip
  • skillUser
    Sorry, I cannot open it, I get an error (from the site):
    Configuration Error
    Description: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately.
    Parser Error Message: An error occurred loading a configuration file: Failed to start monitoring changes to '\\moss2\CSSharedFiles\forums\storage\48' because the network BIOS command limit has been reached. For more information on this error, please refer to Microsoft knowledge base article 810886. Hosting on a UNC share is not supported for the Windows XP Platform.
    Lawrence.
  • skillUser
    A ticket has been filed internally in Cadence for this attachment problem since more than one user has problems accessing the attachment.
  • tpuosu
    tpuosu over 16 years ago
    I am facing the same problem while creating new library in IC-5141. I am getting the following error message:
    <<< Stack Trace >>>
    libManCreateLib("cdkCreateNewLib" "" "" "" "" ... )
    ddsLMCMenuItem(1 "cdkCreateNewLib" "libManCreateLib" ("" "" "" "" ""))
    Can  you tell what you did to fix your problem?
    Thanks a ton!
    We have a Cadence Online Support Solution on this. However, it just gives tips on how to debug it. I see from all the service requests attached to this that everyone who has this issue seems to have been using the NCSU libraries. Can't really debug it (don't have the bandwidth to do this), but perhaps you can either create a service request with Cadence Support, or contact NCSU?
