  3. methods for variable integer to string conversion
  • Replies 16
  • Subscribers 153
  • Views 31410
JMCaJHU
JMCaJHU over 16 years ago
 Is there any way to convert a variable of the integer type to a string.  Currently i must create a set of pins with names varying from IN0 onward.  I tried everything from casting the int to string with quotations to evaluating the symbol/variable then casting into a string with symbolToString.  All seem to be limited with no direct way from int to string.  Currently i have resorted to using random naming for the program to work as follows:
 for(j 0 n
if(j==0 then
db_outnet=dbCreateNet(db_outcell "IN0")
db_figId = dbCreateRect(db_outcell  list("METAL1")  list(0:5.025 0.375:5.4))
dbCreatePin(db_outnet db_figId "IN0")
else
outname=symbolToString(gensym('IN))
db_outnet=dbCreateNet(db_outcell outname)
db_figId = dbCreateRect(db_outcell  list("METAL1")  list(0:(3.7+rth*j) 0.375:(rth*j+4.1)))
dbCreatePin(db_outnet db_figId outname)
db_figId = dbCreateRect(db_outcell  list("METAL1")  list(0:(5.025+rth*j) 0.375:(rth*j+5.4)))
 This creates IN0 then continues creating input pins in numerical order from a random index.  I need to be able to create "IN" + j.string in java terms.
  • skillUser
    skillUser over 16 years ago
    I think what you need is the sprintf() function, for example:
    db_outnet = dbCreateNet(db_outcell sprintf(nil "IN%d" j))
    dbCreatePin(db_outnet db_figId sprintf(nil "IN%d" j))
    Hopefully the above will help you.  If you want to store this in a variable, use the first argument to sprintf for the variable name, e.g.
    sprintf(name "IN%d" j)
    db_outnet = dbCreateNet(db_outcell name)
    dbCreatePin(db_outnet db_figId name)
    Since the counting variable j is an integer, I used %d for the format specifier, but other formats can be used too, such as %L (any format), %f (float), %g (numeric, efficient), %s (string).
    Lawrence.
  • IC Layout
    IC Layout over 16 years ago
     Hi! you can build strings in this way also ...
    choose a proper way according to your need..
    1. artMakeString(300) or artMakeString(12.34)
    2. pcExprToString(320+130) ;; this results in "450"
    I think in your case it seems that the answer given by Lawrence is fine....
    I added these lines to help you in othercase....
    Best Regards...
    Prabhakar. K -- Layout Engineer
  • JMCaJHU
     thanks lawrence. the sprinf command was perfect
  • sprinter
    sprinter over 16 years ago
    Hi Lawrence,
    I shall appreciate if you could help me achieve the opposite, i.e. converting string to a variable.
    I want the vertices of a polygon to be variables with an index (say 'm') included in its name which gets updated in a 'for' loop. I'm unable to assign an integer value to this. Please see below:
    pp1_1x=some integer variable
    pp1_1y=some integer variable
    pp1_2x=some integer variable
    pp1_2y=some integer variable
    and so on.
    In Matlab the vertices names would be as simple as:
    pp(m)_1x=interger variable,
    pp(m)_1y=integer variable, etc. & you can sweep the value of 'm'
    I tried this but obviously this didn't work in SKILL.
    the other thing I tried was this:
    m=1 (say)
    stringToSymbol(sprintf(x "pp%d_1x" m)
    this gives me x="pp1_1x"
     At this point I can assign an integer value to 'x' but "pp1_1x" is still an undefined variable, actually it's still a string.
    Therefore I tried to write to a symbol directly with this:
    printf("pp%d_1x" m)=some integer value
    but this is not even allowed. Please suggest.
    Adil Khalil.
    Personally I think you should really use an array for this (or a table) because that's what arrays are for:
    declare(pp_1x[10])
    and then pp_1x[m]=...
    But if you really want to build a variable name dynamically, you'd do something like this:
    varName=stringToSymbol(sprintf(nil "pp%d_1x" m))
    set(varName 200)
    and now pp1_1x will be set to 200 (say).
  • sprinter
    Thanks Andrew for your suggestions.
    I like the array idea too. However, it would be nice to be able to use a wild card so that I don't have to declare all the variables in the array. e.g. I thought declare(pp**_[10]) would let me declare the array just once for something like: pp1x_[m], pp1y_[m] ,pp2x_[m] ..... I couldn't find anything for a wild card in the Skill Language User Guide either. Is there a wild card in Skill?
    Another question on a different topic if you don't mind :)
    1. What's the best way to read a user input from the keyboard? fscanf would let you read from a file through a port but it wouldn't read from the keyboard entry. I've heard that enterString is the command for this purpose but I couldn't find its usage in the Skill language reference.
    Adil.
  • dmay
    dmay over 16 years ago
    I prefer to use tables whenever I can. They are very efficient and you wouldn't need to declar a fixed size in this case.
    ;Define your table
    varTbl = makeTable("varTbl" nil)
    You could do this in a variety of ways:
    sprintf(varName "pp%d_1x" m)
    varTbl[varName] = myvalue
    OR
    varTbl[list("pp_1x" m)] = myvalue
    OR, if there are a lot of values to deal with, you could create nested tables
    varTbl["pp_1x"] = makeTable("pp1x" nil)
    varTbl["pp_1y"] = makeTable("pp1y" nil)
    varTbl["pp_2x"] = makeTable("pp2x" nil)
    varTbl["pp_2y"] = makeTable("pp2y" nil)
    foreach(m mList
        varTbl["pp_1x"][m] = myvalue1x
        varTbl["pp_1y"][m] = myvalue1y
        varTbl["pp_2x"][m] = myvalue2x
        varTbl["pp_2y"][m] = myvalue2y
    As for reading input from the keyboard, it depends on what you want to do. Are you working in Virtuoso? Then you can use bindkeys. The enterString should be in the documentation.
    enterString(
    [?prompts l_promptList]
    [?form s_form]
    [?initProc t_initProcName]
    [?doneProc t_doneProcName]
    [?formProc t_formProcName]
    [?alwaysMap g_alwaysMap]
    [?cmdName t_cmdName]
    Derek
  • sprinter
    Hi Derek,
    Thank you for your nice suggestion.
    It appears that even if I choose to use tables, I would still need to create as many tables as there're variables which comes to the same as having to declare as many variables if I choose array.
    enterString:
    I want to enter parameters like space, trace width etc. for my transformer (ROD based) code in the CIW window. I want to be prompted for data entry when I load the file. An example would be quite helpful to understand its usage.
      Did find the usage in the 'skillfinder' but without any example. Skill language reference doesn't even list this command.
    Adil.
  • dmay
    Actually, the first two examples I showed you used only one table. The "keys" to the table are either unique strings or unique lists.
    Sounds like you ought to be writing a pcell rather than prompting for parameters in the CIW. Have you looked at the pcell documentation? The enterString help is in the Cadence User Interface Skill Reference.
    As for creating pcells, here is a place to start: /forums/p/12699/19577.aspx#19577
    Derek
    Derek's suggestion is exactly what I'd have said - in fact I nearly suggested it in the first place, but it wasn't entirely clear to me what your objective was.
    Prompting for parameters in the CIW is almost never a good idea. Either the pcell approach or using a form would be a better idea.
    /forums/p/13412/20801.aspx#20801
    for example.
