  3. Error eval:unbound variable -rbenumform in IC613
  • Subscribers 150
  • Views 5738
kbhow
kbhow over 16 years ago
Hi all
I encounter some error in IC613 during TTB function. The error message is: *Error* eval: unbound variable – rbenumform. You can easily re-produce the errors by any cell, by using TTB->rule stretch. I’m suspecting this may related to techfile, but still investigating la. Do anyone knows where this form comes from? And once it is been instantiated, it will cause other function to failed too.
How
    Hi How,
    What subversion are you using? I found CCR 705859 which is about the same error, and the suggestion was that this is a problem only in a particular engineering hotfix, and it's not occurring in ISR14 of IC613 (the customer confirmed this).
  • kbhow
    I'm using virtuoso version IC613.513. I noticed the CCR too but the fixed only done in IC613.514. Is there any workaround for this?
    How
    Hi How,
    I don't know of a workaround - and unfortunately I don't have easy access to the ISR 13 build to a) reproduce the problem and b) come up with a workaround. At least not within my rather limited available time right now.
    The best thing would be to install ISR 14...
  • kbhow
    Thanks a lot for your help. I believe the only thing i can do to solve this issue is install IC614. I can't find any workaround for this as well.
    How
    Hi How,
    It's not IC614 you need (you'd have to wait until the end of November for that), it's ISR 14 of IC613 - ie 6.1.3.500.14, which is the latest hotfix on downloads.cadence.com
  • kbhow
    Thanks a lot. :-)
    How
