  3. prBoundary translation
  • Views 16833
sooky
sooky over 16 years ago
hi all:
 I want to translate my prBoundary of PBCEL wrote as a "rect" in  CDB into  OA with the objType is "prBoundary" .
  the  script in CBD now :
        Bound = rodCreateRect(
               ?cvId          pcCellView
               ?name          "Bound"                           ==> OA : the boundary that  objType is "prBoundary".
               ?layer         list("prBoundary" "drawing")
               ?bBox          list(0.0:0.0 2.0:14.0)
thanks for your help.
    You can either just create the PrBoundary object directly:
    boundObj=dbCreatePRBoundary(
        pcCellView
        list(0.0:0.0 0.0:14.0 2.0:14.0 2.0:0.0)
    or if you want to create a ROD object first (for example, to align to, or whatever) you can do:
           ?cvId          pcCellView
           ?name          "Bound"
    ; after we've finished using the Bound rod object for whatever
    ; we need it for, convert it into a PrBoundary object.
        pcCellView
        list(Bound~>upperLeft Bound~>upperRight Bound~>lowerRight Bound~>lowerLeft)
    ; don't need the original ROD object any more
    dbDeleteObject(Bound~>dbId)
  • sooky
    It works well
    Thank you Andrew.
