  3. Pin Current Probing Issue?
  • Views 15284
hkutuk
hkutuk over 16 years ago
In certain cases the pin currents of cells are stored as numericals instead of the actual pin name. For example a when I look at the simulation outputs via the Results Browser, I see that the pin current value is /../../../io.4 instead of  /../../../io.n2_mid. The pin name n2_mid has been converted into a numerical value of 4 when the result is stored.Is there a way to avoid this conversion?
-Haydar
  • hkutuk
    So does anybody know the rule how a pin name say as above n2_mid gets converted to a numerical value of 4?
    -Haydar
    The number is the order of the pin in the subckt header. There is an option (see "spectre -h options" called "useterms" which you can set to "useterms=name" and then it will save by name rather than index.
    Be cautious though; this can break backannotation in ADE because CDF and so on is most likely set up to expect the pin by order rather than by name.
