  3. help - skill code for goto xy coordinate
  • Replies 23
  • Subscribers 152
  • Views 21759
zeroskills
zeroskills over 17 years ago
i would like some help on skill code for goto xy coordinate. we used to have this skill code, it does this...
pop up goto xy form, just input x and y coordinate then view size, like how zoom in or out you want it. then there will be an "X" ruler mark on the coordinate.
  • zeroskills
    zeroskills over 16 years ago
    To How, Andrew, Derek and Rian - thanks for the help, i really appreciate it. so far, you've helped me with my request to be more productive at work.
    Riad-Initially copying your code to gotoxy.il, it is zoomed and does not have the "X" mark. i will test and look again and follow your comments.
    We don't have an in-house CAD support, we have to call/email CAD support to help us for things like this. With your help on my request, it have been very helpful and make me more productive at work. Thanks again.
  • kbhow
    kbhow over 16 years ago
    By the way, you can simply add a few lines in Riad's code to create the "X" mark using leCreateRuler
     How
  • Satya
    Satya over 16 years ago
    Hi All!! I have modifide kbhow code to zoom and create x marker..please check it out!!
    procedure( ZoomToPoint( x y @key
     (scale 1)
     (winId hiGetCurrentWindow())
     (cvId geGetEditCellView()))
    let(( (dx 1) (dy 1) qcBbox)
    ; Zoom to point with scale
    hiZoomWindowAtPoint(winId scale x:y)
    printf("\nCmd: Zooming to Point %L %L with scale %L\n" x y scale)
    ; Create cross mark using ruler
    qcBbox = list( list( (x - dy) (y - dy)) list( (x + dx) (y + dx)))
    leCreateRuler( cvId list(x:y x+dx:y+dy))
    leCreateRuler( cvId list(x:y x+dx:y-dy))
    leCreateRuler( cvId list(x:y x-dx:y+dy))
    leCreateRuler( cvId list(x:y x-dx:y-dy))
    hiZoomIn(winId qcBbox)
      );let
     );proc
    procedure( zoomGUI()
     let(()
     ; Create form
    hiCreateAppForm(
    ?name 'zoomGui
    ?formTitle "Zoom and Mark"
    ?callback "zoomGuiCB(zoomGui->column->value)"
    ?fields list(
     list( hiCreateStringField(
     ?name 'column
     ?prompt "Go to:"
     ) 5:5 200:25 50)
     ?buttonLayout 'OKCancel
     ?help ""
    hiDisplayForm(zoomGui)
     );let
     );proc
    procedure( zoomGuiCB(input)
     let((dX dY (zscale 1))
     value = parseString(input " ")
     ; Process form' value
     if( length(value) == 2 then
     dX = atof(car(value))
     dY = atof(cadr(value))
     else
     if( length(value) == 3 then
    zscale = atof(caddr(value))
     else
    warn("Zoom to Pt => Invalid input! Input must be x y scale")
     );if
     );if
     ; Calling function to zoom
    ZoomToPoint(dX dY ?scale zscale)
    );let
    );proc
    hiSetBindKey("Layout" "Ctrl<Key>p" "zoomGUI()")
    Satya..
  • Guruprasad S
    Guruprasad S over 11 years ago
    Hi , iam using this skill to zoom , but in this skill we need to enter x , y coordinates everytime.
    I have a set of 100 x , y coordinates , it must be given one after the other automatically by pressing NEXT button PREVIOUS botton ..
    (8.925,5.026)
    (0.586,4.256)
    (2.548,8.412)
    (4.568,2.195)
    Can any one suggest me how that can be done .
    procedure( zoomToPointFormCB(form)
      let((point xCoordinate yCoordinate)
        xCoordinate=car(parseString(form->xyCoordinates->value ","))
        yCoordinate=cadr(parseString(form->xyCoordinates->value ","))
        point=list(cdfParseFloatString(xCoordinate) cdfParseFloatString(yCoordinate))
        printf("The Selected Point is: %L\n" point)
        zoomToPointCB(point)
    ; procedure : zoomToPointCB.
    ; This is the main function, it does dynamically calculate the
    ; zoom ratio and then pan. It also put the ref point that is displayed
    procedure( zoomToPointCB(point)
      let((windowId viewBBox zoomVal)
        windowId=hiGetCurrentWindow()
        hiZoomAbsoluteScale(windowId 1)
        viewBBox=hiGetViewBBox(windowId)
        zoomVal=max(abs(yCoord(upperRight(viewBBox))-yCoord(lowerLeft(viewBBox)))
                    abs(xCoord(upperRight(viewBBox))-xCoord(lowerLeft(viewBBox))))
        ;The zoom can be made even higher, just by seeting value
         zoomVal=20*zoomVal
        hiPan( hiGetCurrentWindow() point)
        hiZoomRelativeScale(windowId  zoomVal)
        unless(leEditorOptionsForm->options->displayRefPoint->value
         leEditorOptionsForm->options->displayRefPoint->value=t
        leSetRefPoint(windowId~>cellView point)
    ; procedure : zoomToPoint, main entry.
    procedure(zoomToPoint()
      unless(boundp('zoomToPointForm)
        zoomToPointCreateForm()
      hiDisplayForm(zoomToPointForm)
    ; procedure : zoomToPointCreateForm
    procedure(zoomToPointCreateForm()
      let((xyCoordinates zoomLabel zoomButton)
        zoomLabel=hiCreateLabel(
          ?name 'zoomLabel
          ?labelText "Enter ',' Separated Points: ex 0.0,0.0"
          ?justification `center
        xyCoordinates=hiCreateStringField(
          ?name 'xyCoordinates
          ?prompt "X,Y Coordinates"
          ?value "0.0,0.0"
        zoomButton=hiCreateButton(
          ?name 'zoomButton
          ?buttonText "Zoom & Pan"
          ?callback strcat("(zoomToPointFormCB " 'zoomToPointForm " )")
       zoomToPointForm=hiCreateAppForm(
          ?name 'zoomToPointForm
          ?formTitle " Zoom To Point"
          ?buttonLayout '(OKCancelDef)
          ?fields list(
            list(zoomLabel 5:5 250:30 100 )
            list(xyCoordinates 5:40 250:30 100 )
        list(zoomButton  30:75 200:30  )
    ; Bindkey definition
    hiSetBindKey("Layout" "Alt<Key>z" "zoomToPoint()")
  • theopaone
    theopaone over 11 years ago
    Is your data in a file or a SKILL list? It looks like strings from a file.
    I would not use the form at all as it is harder to stuff the data in the form than process it directly. Write a function that gets the next value in the list, converts it to points (like zoomToPointFormCB) and calls zoomToPointCB.
    Use inFile to open the file, each time you read a line (lineread) you will get the next point represented as a string.
  • Guruprasad S
    Hi ,
    I have set of X Y Coordinates in a text file , that is " coordxy.txt "
    this fie has coordinates in the form of (X Y)
    1.2 6.8
    2.4 4.6
    6.2 2.9
    0.4 6.0
    5.0 8.9
    this is saved in file " coordxy.txt "
    I wrote another skill to load this "coordxy.txt " file in CIW and assigned it to  portt=infile(hiGetCurrentForm()->fileLocation->value)
    /*** Skill to load file in CIW **/
     procedure( loadfile()
        let( (fileLocation loadFileButton y)
            fileLocation = hiCreateFileSelectorField(
                    ?name           'fileLocation
                    ?mode           'existingFile
                    ?prompt         "Choose a file"
                    ?editable       t)
            loadFileButton = hiCreateButton(
                    ?name           'loadFileButton
                    ?buttonText     "Load File"
                    ?callback       "printf(\"Loading file from popup form %s\n\" myForm->fileLocation->value)")
            myForm = hiCreateAppForm(
                    ?name           'myForm
                    ?formTitle      "Load File in CIW"
                    ?buttonLayout   'Close
            ?dontBlock t    ; with this your previous code would have failed
                    ?fields         list( list(fileLocation 10:10 400:20 100)
                                            list(loadFileButton 415:10 80:30))
                    ?unmapAfterCB           t)
            hiDisplayForm(myForm)
        ); let
     port=infile(hiGetCurrentForm()->fileLocation->value)
    hiSetBindKey("Layout" "Alt<key>L" "loadfile()")
    ----------------------END-----------------------
    Now i should read this file in CIW line by line, for this i have some code
    fpFile = infile(" 123.txt ")
    gets( line fpFile )
    tokens = parseString( line )
    rexCompile( "[xyXY] *[=:]")
    coord = rexReplace( line " " 0)
    rexCompile( "[(){}=,:]")
    coord = rexReplace( coord " " 0)
    rexCompile( "\\. ")
    coord = parseString(coord)
    coord=mapcar( 'aelNumber coord)
    coord=setof(x coord x)
    X=car(coord)
    Y=cadr(coord)
    this will get value of X and Y from file line by line
    Next i need this values to assign in my main code one by one , by pressing NEXT BUTTON in pop up window , and it must go to previous line by Pressing PREVIOUS BUTTON .
  • theopaone
    I would read in all the coordinates from the file and create an ordered list. Then the file could be closed.Parse the list using the nth command (index starts with 0). Create your own GUI, next would add one to the index, previous would subtract one.
  • Karthik Punna
    Karthik Punna over 7 years ago in reply to Satya
    Hi Satya,
    I'm using your code,
    But it showing an error while working on it i.e., too few arguments (at least 2expected , 1 given) - ((length ((value ==2)then (dx = atof(&)) (dy = atof(&))...))
    Could you please suggest me  how to fix the error .
    Karthik P.
    Andrew Beckett over 7 years ago in reply to Karthik Punna
    You appear to have mangled the code somehow when copying and pasting it, and have added spaces in some places and probably removed them elsewhere. I copied the code and loaded it, and it worked fine. The error suggests that you have a space after the length function name (in SKILL in C-style you must not have a space between the function name and the following open parenthesis.
  • Karthik Punna
    Karthik Punna over 7 years ago in reply to Andrew Beckett
    Thank You , Andrew
    Karthik P.
