  3. help - skill code for goto xy coordinate
  • Replies 23
  • Subscribers 152
  • Views 21771
zeroskills
zeroskills over 17 years ago
i would like some help on skill code for goto xy coordinate. we used to have this skill code, it does this...
pop up goto xy form, just input x and y coordinate then view size, like how zoom in or out you want it. then there will be an "X" ruler mark on the coordinate.
  • Karthik Punna
    Karthik Punna over 7 years ago in reply to Satya
    HI Satya/Andrew,
    The Above code is only for the single coordinate with scaling factor like (2.0 5.0 2) .
    I want improve the code like it should be take multiple coordinates at single time and mark the same multiple coordinates at a time.
    could you please help me out in this.
    Karthik  P.
    Andrew Beckett over 7 years ago in reply to Karthik Punna
    Karthik,
    Given this code was written 9 years ago and I can't see other posts by Satya (at least not recently), I suspect you won't get an answer. Not sure I have the time to take the code, reformat it (to understand it - the indentation is missing) and update it, especially when it doesn't really make sense to have it zoom to multiple coordinates - after all, much of the point of the code was to zoom to the specified location - you can't zoom to multiple locations.
    If you want to modify it yourself though, you could remove the zooming part (the hiZoom* functions in the code above) and then have a loop which did something like this (replacing part of the code above).
    ; Process form value
    while(value
      if( length(value) == 2 then
        dX = atof(car(value))
        dY = atof(cadr(value))
        zscale = 1 ; NOTE DEFAULT HERE
      else
        if( length(value) >= 3 then  ; NOTE CONDITION CHANGED
          zscale = atof(caddr(value))
        else
          warn("Zoom to Pt => Invalid input! Input must be x y scale")
        );if
       );if
      ; Calling function to zoom
      ZoomToPoint(dX dY ?scale zscale)
      ; remove three values
      value=cdddr(value)
    I've not tested the above - it's just a quick typed bit of code which probably would do what you want - and if not, probably gives you the basis of what you need.
  • Karthik Punna
    Karthik Punna over 7 years ago in reply to Andrew Beckett
    Thank You, Andrew
    Karthik P.
