  3. How to create two or three key strokes bindkeys
  • Replies 21
  • Subscribers 154
  • Views 35988
SlimAnt
SlimAnt over 17 years ago
How can I create two or three key strokes bindkeys without changing the existing bindkeys?
For example, addition of existing bindkeys such as: m -> to activate move
I would like to create new bindkeys such as: jmp -> SKILL code to jump to a certain coordinate
I tried using the following function getc to read the next character from keyboard and it doesn't work.
   procedure( call_2()
        TT = getc()
                if( TT = "p" then
                     ; function to jump
   procedure( call_1()
          TT = getc()
                 if( TT = "m" then
                        call_2()
hiSetBindKey("Layout" "none<Key>j" "call_1()")
I am using version IC6.1.3
I Appreciate any help that I can get.
  • Varungr087
    Varungr087 over 7 years ago in reply to Andrew Beckett
    Understood ! So now to get it back to whatever it was before initialising the code, I have to re invoke virtuoso. Right ?  or Is there any other alternative other than re-invoking ?
    Andrew Beckett over 7 years ago in reply to Varungr087
    You can just re-load the standard bind keys file. Either:
    load(ddGetStartup("dfII/bindkeys/Layout.il"))
    or:
    load(prependInstallPath("samples/local/leBindKeys.il"))
    That's assuming you are using the "out of the box" bindkey definitions. The top function (with ddGetStartup) would work if you've put a dfII/bindkeys/Layout.il further up your "Cadence Search File" path, but if you've loaded some other custom bind keys from  your .cdsinit you'd need to locate that and re-load it.
  • Varungr087
    Ok Andrew. Thanks again
  • wklane
    wklane over 5 years ago in reply to Andrew Beckett
    is there any recent revisions?  I cant get it to work
    Andrew Beckett over 5 years ago in reply to wklane
    Hmm, something got messed up in the formatting on the forum site, and so some of the code where the bind keys were being formed got screwed up - I suspect the <Key> parts were being confused as HTML. I copied the code from the forum, and when I tried to initialise:
    abSeqBindKey->initBindKeys("Layout")
    I got loads of messages like this:
    *WARNING* Invalid bindkey key string: Shiftt
    Anyway, I've re-uploaded the code (I replaced it in the post above) and now it should be OK. I'm assuming you kept the .ils suffix in the file, that you'd loaded it, and you called the abSeqBindKey->initBindKeys("Layout") function to initialise everything?
    Let me know if that doesn't fix your problem - and if it doesn't, please describe what you've done, and what happens... the code itself hasn't needed changing in 11 years; I just tested it using IC6.1.8 ISR15 (using the samples in the comments at the top of the code).
  • wklane
    I think I am missing something basic.  First the get, set and reset functions wouldnt load, it errored saying they were internal functions and couldnt be re-defined.  I appended an _f to the end of them and their respective calls to get it to load. It does load now but nothing seems to have changed in my environment.....ie, all my keys operate as initially defined at startup
    It sounds as if you did not keep the file suffix as “.ils”. That is important - otherwise it won’t get loaded using SKILL++ semantics and the local functions will clash with existing global functions. You should not need to rename any function to make this work. What did you call the file name you stored the code in?
  • wklane
    mbind.ils
  • wklane
    wklane over 5 years ago in reply to wklane
    I put everything back as you had it and correct extension. it loads fine but still no change
    Well, if I either give the file the .il suffix, or omit the let() around everything in the code, then I get an error like this when loading:
    *Error* define: can't redefine an internal function - reset
    *Error* load: error while loading file - "~/shared/xfer/mbind.ils" at line 161
    Are you just loading the file with load("mbind.ils") ? Or are you copying and pasting the code into the CIW (which won't work)?
    Please give an exact transcript of what you're doing - it doesn't make any sense to me, since this is very simple - you put the code in a file with a .ils suffix, then load("thatfile.ils") and then initialise using  abSeqBindKey->initBindKeys("Layout") and finally define some multi-key bind keys as described at the top of the file in the comments.
