  3. How to create two or three key strokes bindkeys
  • Replies 21
  • Subscribers 154
  • Views 35996
SlimAnt
SlimAnt over 17 years ago
How can I create two or three key strokes bindkeys without changing the existing bindkeys?
For example, addition of existing bindkeys such as: m -> to activate move
I would like to create new bindkeys such as: jmp -> SKILL code to jump to a certain coordinate
I tried using the following function getc to read the next character from keyboard and it doesn't work.
   procedure( call_2()
        TT = getc()
                if( TT = "p" then
                     ; function to jump
   procedure( call_1()
          TT = getc()
                 if( TT = "m" then
                        call_2()
hiSetBindKey("Layout" "none<Key>j" "call_1()")
I am using version IC6.1.3
I Appreciate any help that I can get.
  • wklane
    wklane over 5 years ago in reply to Andrew Beckett
    ok, i got it to work.  operator error, my file editor didnt indicate the first section as comments and I assumed they had be executed.  thanks for your patience
