  3. Add function into rodCreatePath
  • Replies 7
  • Subscribers 153
  • Views 19241
user002
user002 over 16 years ago
Hi all, I've been reading your posts for about 2 months, I'm trying to learn skill and they're very useful! thanks.
I'm asking for help here because I don't know how to do properly the next thing:
I want to add for example 100 lines of subRects with a separation of 1 to my MultiPart Path, I've created this function:
;----------------Function------------------
procedure(anillo(w puntos)
  cv = geGetEditCellView()
  mipath = rodCreatePath(
        ?layer           list("M1" "logic")
        ?width           w
        ?pts             puntos
        ?endType         "flush"
        ?cvId            cv
        ?encSubPath      list(
           list(
             ?layer        list("XN" "logic")
             ?enclosure    -0.22
             ?beginOffset  0.22
             ?endOffset    if(pathstate~>closed then -0.22 else 0.22)
           );NWell
           list(
             ?layer        list("ACTIVE" "logic")
             ?enclosure    -0.04
             ?beginOffset  0.04
             ?endOffset    if(pathstate~>closed then -0.04 else 0.04)
           );Active
        ) ;encpath
        for(i 0 99
          ?subRect         list(
            list(
              ?layer      list("CS" "logic")
              ?width      0.22
              ?length     0.22
              ?endOffset  -0.06
              ?beginOffset -0.06
              ?space      0.28
              ?sep        i  ;This gives me the separation.
            );contactos
          );subrect
        );for
  ) ; end rodCreatePath
);proc
;------------------EOFunction----------------
But when I try to run it with my parameters OK it says:
;--------------------CIW Window---------------
 *Error* rodCreatePath: extra arguments or keyword missing - (t)
;--------------------End of CIW Window-----------------
It's just because the "for()" function returns "true" (t) . (I think.)
What could I do to solve this? Any other good technique for doing this? Thanks in advance.
    Yes, the problem is partly because for() returns t, and also because you've got the ?subRect within the for loop.
    Easiest way to do this is probably to build a list of integers from 0 to 99, and then use foreach(mapcar) to transform this list of integers into the subRect entries.
    For example this modification to your code (I suspect you'll need to adjust it, because I think all the contacts aren't in the right place, but I'm sure you can take care of that part).
    procedure(abSequence(start stop)
      let((i seq)
        i=stop
        while(i>=start
          seq=cons(i-- seq)
        seq
            ?width           w
            ?pts             puntos
            ?endType         "flush"
            ?cvId            cv
            ?encSubPath      list(
               list(
                 ?enclosure    -0.22
                 ?beginOffset  0.22
               );NWell
               list(
                 ?enclosure    -0.04
                 ?beginOffset  0.04
               );Active
            ) ;encpath
    	?subRect
    	  foreach(mapcar i abSequence(0 99)
                list(
                  ?width      0.22
                  ?length     0.22
                  ?endOffset  -0.06
                  ?beginOffset -0.06
                  ?space      0.28
                );contactos
              ); foreach abSequence
    );proc
  • user002
     Thank you very much Andrew. It works nice.
  • johnmck
    johnmck over 15 years ago
    Andrew, the code above was very helpful but I am having a syntax problem when I try to add a second layer into the foreach.  I couldn't add a second foreach loop either.  Here is an example of what I'm trying to do.  Thanks,  John
     ?subRect
                list(
                  ?width      0.22
                  ?length     0.22
                  ?endOffset  -0.06
                  ?beginOffset -0.06
                  ?space      0.28
                );contactos
                list(
                  ?layer      list("V1" "logic")
                  ?width      0.22
                  ?length     0.22
                  ?endOffset  -0.06
                  ?beginOffset -0.06
                  ?space      0.28
                );contactos2
  • lrl12skdev
    lrl12skdev over 15 years ago
     Hi johnmick,
    I think it's because your argument for ?subRect is wrong, it is expecting a single list but you are giving him 2. the best way I guess is to form the list outside the rod function, let say you build the list and call it subrectlist then you can just simply write ?subRect subrectlist
    example
    list1 =   foreach(mapcar i abSequence(0 99)
                list(
                  ?width      0.22
                  ?length     0.22
                  ?endOffset  -0.06
                  ?beginOffset -0.06
                  ?space      0.28
                );contactos
    );foreach
    list2 = foreach(mapcar i abSequence(0 99)
                list(
                  ?width      0.22
                  ?length     0.22
                  ?endOffset  -0.06
                  ?beginOffset -0.06
                  ?space      0.28
                );contactos
    );foreach
    subrectlist = append(list1 list2)
     of course this is just a quick and dirty solution to show what I mean but you can do it in more efficient way perhaps avoiding append function.
  • johnmck
    That works!  Thanks!  I knew it was a simple fix, I just couldn't find it.
    The other way would be to do something like this (using foreach mapcan):
     ?subRect
      foreach(mapcan i abSequence(0 99)
    list(
                list(
                  ?width      0.22
                  ?length     0.22
                  ?endOffset  -0.06
                  ?beginOffset -0.06
                  ?space      0.28
                );contactos
                list(
                  ?width      0.22
                  ?length     0.22
                  ?endOffset  -0.06
                  ?beginOffset -0.06
                  ?space      0.28
                );contactos2
    Apologies for the formatting - replying from a hand-held device. Foreach mapcan will merge the lists in the body of the foreach as it proceeds.
  • johnmck
    Andrew, thanks for the help.  I had tried that but didn't change the mapcar to mapcan!!!
