  3. Plz help in solving the error: *Error* let: local bindings...
  • Replies 8
  • Views 18930
Plz help in solving the error: *Error* let: local bindings must be a proper list
Anupama
Anupama over 16 years ago
I am excuting below piece of code. I very new to this skill programming. I am still a beginer. I am stuck at variable declaration.  But I need make this piece of code to work ASAP. So please suggest me what is wrong in this code.?...
MY ERROR : *Error* let: local bindings must be a proper list - cv
CODE :
procedure(CCSPowerPlot(pinlist)
let(cv layername) cv=geGetEditCellView()foreach(pin pinlistforeach(shape cv~>shapes
if(pin==shape~>net~>name then
layername=car(shape~>lpp)
lelsLayerSelectable(list(layername "drawing") t)
hiRedraw()
  • kbhow
    kbhow over 16 years ago
    Hi Anupama,
    I corrected your code as below:
    let((cv layername)   ;;You miss a bracket here
        cv =geGetEditCellView()
        foreach(pin pinlist
                    hiRedraw()
                 );if
           ) ;foreach
        );let
    );proc
    Please have a try again
    How
  • skillUser
    skillUser over 16 years ago
    You appear to be missing a set of parentheses (or more? I have not tested the code below, just inspected it "by hand" as it were)
    let((cv layername)
    foreach(pin pinlist
    hiRedraw()
    );if
    );foreach
    );foreach
    );let
    );procedure
    I hope that this helps,
    Lawrence.
  • kbhow
    Ophs,
    I miss out a bracket too.
    How
  • Anupama
    Hi All,
     Thanks for the help. The code is executing properly and it is returning "t" value. But it's not showing any changes in my layout. It is not selecting the respective layer.
    I am passing my arguments in this way.
    pinlist='("avdd")
    Is this the right way?...
  • kbhow
    Hi Anupama,
    Ya, from your code, you are passing the correct argument. By the way, may i know what are you trying to do. The Skill code looks nothing for me, it just check on the layer select-ablity on your input net.
    How
    Anupama,
    My guess is that you forgot to add the call:
    geSelectFig(shape)
    where you have the call to leIsLayerSelectable. In fact that function would only return whether the layer is selectable or not, and even then you're passing the second argument wrong (it needs to be a tech file id, or just miss it out since it's optional. Either way, you're doing nothing with the result.  Perhaps you meant to use leSetLayerSelectable? (you'd still need the geSelectFig if you want it to actually select anything).
  • Anupama
    Yup .. Actually the program is just a small check to know whether the layer is selectable or not.
    Actually , My requirement is : I have a pin list . I want to make visible of the net which is connected to that pin only. And I want other nets( of any metal layer) to be invisible. (And addition to this , I want to make visible of my basic layers: poly, n well, diffusion )
    "Mark net" is a option to mark a net. But it doesn't switch off the other nets. I want to do it. I don't know how difficult to achieve it in skill. But I want to try it out.
    What I thought is , first I will take the pin- then will read corresponding net, its shape , its respective Metal layers. I want to select these layers and want to make visible of only this net's layer parts.  Not other nets and its layers.
    Can anyone suggest me, how I can achieve this? Is the right way I am going. Or Is there any other alternative or any already available resource is there to get my result..?
    Anu
  • dmay
    dmay over 16 years ago
    You will not be able to turn off the other nets if they are using the same material as your specified net. In other words, there is no way to show metal1 on your specified net and not show metal1 anywhere else. The nice thing about using something like mark-net is that is uses a separate hilight layer. You can then make all of your metals invisible and still see this hilight layer.
    Once you start using Cadence 6.1, you could select the shapes on your net and use the "Dimming" feature on the Display Options form. This allows you to dim all layout except the selected layout. Thus, you could modify your skill code to select the shapes on a net. These shapes would be clearly visible while the rest of the layout was dimmed.
     Derek
