  3. flattening only specific geometries
  • Views 15051
DaveDesigner
DaveDesigner over 16 years ago
I would like to flatten multiple levels of hierarchy but for only geometries that are on a specific layer? For instance, if at toplevel, I would like to pull all of the 'M1 drawing' layers from any cell in the hierarchy and make it part of the toplevel.
Any ideas? Thanks.
  • DaveDesigner
     Not sure how this post works exactly. I thought my edits would be visible to everyone but doesn't seem to be. I copied my notes below.
    [<b>edited by:</b> DaveDesigner at 7:33 AM (GMT -8) on 11 Nov 2009]
    I found a work-around with Solution ID: 11561834
    If anybody already has a solution for the original request, I would be happy to have it; otherwise, this request can be considered closed.
    Look also at solution 11328674. Apologies for the delay - I needed to re-publish the solution because of some formatting changes required during the migration from Sourcelink to Cadence Online Support.
    Best Regards,
