  3. dbCreateParamSimpleMosaicByMasterName
  • Subscribers 152
  • Views 16497
SANKALP
SANKALP over 16 years ago
When I am  using dbCreateParamSimpleMosaicByMasterName command pcell is coming but length and width are not coming correct for MOS pcell. What is problem?
If any one know this then please reply.
  • user002
    user002 over 16 years ago
    Hi, I always use  dbCreateParamSimpleMosaic()
    Here is an example:  1 row, 4 colums, W=1.0, mylib->pmos mosaic.
          cv ;Our cellview
          dbOpenCellViewByType("mylib" "pmos" "layout")
          nil ;Default name
          list(0.0 0.0) ;Where to place the mosaic
          "R0" ;No rotation
          1 ;N. of rows
          4 ;N. of colums
          5.0 ;Offset X (from 0.0)
          5.0 ;Offset Y (from 0.0)
         ;And the list of my parameters.
          list(
            list(
              "w" "float" 1.0
  • SANKALP
    Thanks!
    Using this command pcell coming but its taking minimum values of width and length. Its not taking what ever  passing through list.
    The most likely scenario is that you got the names of the parameters wrong, or the type of the parameters maybe - but most likely the parameter names.
    Check them by doing:
    cv=dbOpenCellViewByType("libName" "pcellName" "layout")
    cv~>parameters~>value~>name
    Perhaps you can post both the output of the above statement, and also the SKILL call you have to dbCreateParamSimpleMosaicByMasterName (or dbCreateParamSimpleMoasic) so we can see what you're doing. I don't know of any problems with these functions (as far as I can recall). Also which version of the software you're using could be useful to know (type getVersion(t) in the CIW).
