  3. A question about flattening instances upto stoplevel preseving...
  • Views 14890
A question about flattening instances upto stoplevel preseving vias?
IC Layout
IC Layout over 16 years ago
Hi! All, I am using cadence IC514 version .. & .. tsmcN65nm PDK ..
In this PDK all vias are of type instances..
I am trying to flatten the entire cellview by preserving VIAs .. But I am in vain ..
Here is the code which will give an idea about what I am trying to do with ...
procedure(FLATTEN_INST()
foreach(inst deGetCellView()~>instances
       if(inst~>mosaic then
               leFlattenInst(inst~>mosaic 31 t nil nil)
       else
       if(!leIsAnyContact(inst)
               leFlattenInst(inst 31 t nil nil)
);flatten_inst
The procedure FLATTEN_INST() has to flatten all instances upto stoplevel preserving VIAs ..
k1='()
procedure(inst_box(cv1 layer1 layer2 @optional (layer3 '("prBoundary" "drawing")))
l1=leLayerAnd(cv1 layer1 layer2 layer3)
foreach(box l1
       l2=dbGetTrueOverlaps(cv1 box~>bBox)
       foreach(ele l2
               if(leIsAnyContact(ele) then
               if(nth(0 area(ele~>bBox)) <= nth(0 area(box~>bBox))/2 || nth(1 area(ele~>bBox)) <= nth(1 area(box~>bBox))/2 then
                       ;geAddHilightRectangle(h1 box~>bBox )
                       k1=cons(box~>bBox k1)
dbDeleteObject(box)
k1
inst_box(deGetEditCellView() '("M1" "drawing") '("M2" "drawing"))
inst_box(deGetEditCellView() '("M2" "drawing") '("M3" "drawing"))
geResetCellView(deGetEditCellView())
Please, Can some one guide me to solve this issue ...
Thanks in Advance ...
Prabhakar. K -- Layout Engineer
    Prabhakar,
    It might help if you actually described what the problem was. I tried the FLATTEN_INST() function and it worked for me. I couldn't try inst_box() because it was missing the function area() (I could guess, but to be honest I decided not to bother because I couldn't be sure what you were expecting the code to do).
