  3. ESD instances list .
  • Views 14988
marbs
marbs over 16 years ago
 Hi all,
I would like to ask, how can I make a SKILL file to
display a list of all ESD instances from the schematic to
the CIW ?
Thanks in advance,
Marbs
  • skillUser
    skillUser over 16 years ago
     Hi Marbs,
    This sounds similar to my recent post on finding certain schematic instances, take a look.  To help I will repeat the SKILL code snippet here.
    cv = geGetEditCellView()
      => db:0x452bdf92
    esdCells = setof(inst cv~>instances rexMatchp("^[eE][sS][dD]" inst~>cellName)) => (db:0x452bdc12 db:0x452bdc13)
    ;; show the cell names in a list
    esdCells~>cellName => ("esdBigDiode1" "ESDclampCell")
    The above example is looking for any instance in the current schematic that matches a cellname that starts with "esd" or "ESD", for example. You have not given much information to work with, so I can only assume to find the cells by name, as in the above example, but there could be other ways.  If the instance name were set following a methodology, then you might use a function like dbFindAnyInstByName() which takes the cellview dbId and an instance name as input, e.g. dbFindAnyInstByName(cv "ESD0").
    I hope that this helps you!
    Lawrence.
  • marbs
    Thank you sir for the reply.
    The code is working fine.
     It is what I need.
