  3. Loading LayerSets with a bindkey
  • Subscribers 152
  • Views 15232
isgdude
isgdude over 16 years ago
I wish to load a LayerSet file using a bindkey instead of LSW->edit->Layer Sets->load
The location of my layerSet file is:
./.cadence/dfII/layerSet/bicmosSige/mylayers.layerSet
Everytime I drop down into a cellview, the default LSW layers are displayed and I  need to reload my LayerSet file.
Even when I return to the upper levels, I need to reload the file.
I'm mainly using layerSet to reorder the layers in the LSW.  The techfile is controlled, so I can't edit it.
I can't seem to find very much Skill info on LayerSets in the documentation or on sourcelink.
Randy
  • Quek
    Quek over 16 years ago
    Hi Randy
    I think there are 2 ways to solve the problem:
    a. Save your layers as the default layers. Go to lsw "Edit->Layer Sets" and select "Save default".
    b. Use the following skillscript. It will autoload your layers whenever a layout is opened. I have also associated the loading to key F4.
    procedure( CCSautoLoadLS(args)
       let( (layerSetName)
          layerSetName="mylayers"
          _leLSWLayerSetForm->_leLSWLayerSetRadio->value="Load"
          _leLSWLayerSetForm->_leLSWLayerSetChoices->value=layerSetName
          hiFormDone(_leLSWLayerSetForm)
          printf("LayerSet %s autoloaded for cellview : %s\n"
            layerSetName args->cellName)
       ) ;let
    ) ;procedure
    hiSetBindKey("Layout" "F4" "CCSautoLoadLS(geGetWindowCellView())")
    deRegUserTriggers("maskLayout" nil nil 'CCSautoLoadLS)
    deRegUserTriggers("maskLayoutXL" nil nil 'CCSautoLoadLS)
    if( rexMatchp("virtuoso" getVersion()) then
       deRegUserTriggers("maskLayoutGXL" nil nil 'CCSautoLoadLS)
    ) ;if
    if( rexMatchp("icfb" getVersion()) then
       deRegUserTriggers("maskLayoutTurbo" nil nil 'CCSautoLoadLS)
    ) ;if
    I think option "a" is better because the skillscript makes use of the private variable  _leLSWLayerSetForm.
    Best regards
    Quek
    autoLoadLS.il
