  3. dbCreateVia() questions: justification and other exampl...
  • Replies 7
  • Subscribers 152
  • Views 21743
dbCreateVia() questions: justification and other examples
TrevorB
TrevorB over 16 years ago
I am migrating my pcells to IC6, and I am wrestling with the new via model.  Our PDK uses "standard vias", so I understand that I need to use the dbCreateVia function.
Apparently, I can override paramaters, even for standard vias, so I can use the following syntax:
dbCreateVia(cvId viaId list(x y) list(list("cutRows" 2) list("cutColumns" 3)))
However, I need to alter the justification to "lowerLeft".  This leads me to a few questions:
  1. How do I specify the justification using dbCreateVia?
  2. Does anybody have a "fully involved" dbCreateVia example that uses all possible options?  The manual is a little weak, methinks.
  3. How do I change the justification after I have created the via?  I cannot find it any where in the returned viaId, its header, its viaDef, or the header's master.
Thanks!
Trevor
  • kbhow
    kbhow over 16 years ago
    Hi Trevor,
    There is several unique stuff in creating via compare to other instances. As what i know, there is no pption to specify the justification if you using SKILL function -dbCreateVia to create via rather than the GUI.
    Fortunately, the justification can be specific by doing some manual calculation and input the value as an option - "originOffset". The full syntax of dbCreateVia will be:
        dbCreateVia(  d_cvId d_viaDefId l_origin t_orientation l_paramlist)
        eg: dbCreateVia( cvId vidDefId list(x y) "R0"
                                                 list( list("cutRows" 2)             ;row
                                                 list("cutColumns" 4)               ;column
                                                 list("cutSpacing" list(x y))       ; cut spacing for x and y
                                                 list("layer1Enc" list(x y))         ; enclosure for layer1
                                                 list("layer2Enc" list(x y))         ; enclosure for layer2
                                                 list("cutWidth" 0.2)                 ; cut width
                                                 list("cutHeight" 0.4)                ;cut height
                                                 list("originOffset" list(x y)))      ; justification
    You can change the justification by changing the option -"originOffset". The input must be in l_point which specify the x and y offset from center of the via. A mathematic calculation is needed to measure the distance from the origin point to the center of the via.
    How
  • TrevorB
    Thanks, How!
    Let's say, I wanted to specify the  x-cutSpacing, but I did not know the y-cutSpacing, and I wanted to leave the y-cutSpacing at the default value.
    How would I do this inside the pcell's SKILL environment?  Surely, there is something more elegant than lxComputeViaParams.  Does it even work in the pcell environment?
    Please create a service request at Cadence Customer Support. lx functions are not legal in pcells, so that's not an option; I'm not aware of a convenient way of doing this within a pcell, so it would be best to ask via customer support and  then  an enhancement request can be filed, and maybe R&D can come up with a workaround.
  • TrevorB
    Thanks, Andrew!  I filed a SR.  Hopefully, R&D can come up with something.
  • Tsien
    Tsien over 14 years ago
    Just wondering if you were able to come up with a solution to your problem?  I would also like to write some skill code to convert one via type to another.  But it seems like the only way possible in IC6 is to delete the old via and recreate a new one.  But to create an identical via to the original, I would need to set the parameters such as justification.
     Thanks.
  • TrevorB
    TrevorB over 14 years ago
    I never found or was given a clean solution.  I wrote some bimodal code to consistently place a contact in either IC5.1 or IC6.1, like below.
    HTH,
    Trevor
    procedure(apcCreateContact(@key                   ;_Oct  7 11 tbowen 528
                                cv
                                master
                                origin
                                rotation
                                width
                                height
                                rows
                                columns
                                xPitch
                                yPitch
                                xBias
                                yBias
                                viaEdgeCenter
      let((inst params)
        unless(origin
           origin = 0:0
        unless(rotation
           rotation = "R0"
        if(isOA()
           then
           when(rows
              params = append1(params list("cutRows" rows))
           when(columns
              params = append1(params list("cutColumns" columns))
           when(xPitch && yPitch && width && height
              params = append1(params list("cutSpacing" list(xPitch-width yPitch-height)))
           when(width
              params = append1(params list("cutWidth" width))
           when(height
              params = append1(params list("cutHeight" height))
           inst = dbCreateVia(cv master origin rotation params)
           when((stringp(xBias) && rexMatchp("[lLrR][eEiI][fFgG][tThH]" xBias) && columns > 1) ||
              (stringp(yBias) && rexMatchp("[lLuU][oOpP][wWpP][eE][rR]" yBias) && rows > 1)
              if(numberp(viaEdgeCenter)
                 then
                 xOffset = yOffset = 0.0
                 bBox = inst~>bBox
                 when(stringp(xBias) && !rexMatchp("[cC]enter" xBias) && columns > 1
                    cond(
                       (rexMatchp("[rR]ight" xBias)
                        xOffset = viaEdgeCenter - width(bBox)/2.0
                       (rexMatchp("[lL]eft" xBias)
                        xOffset = width(bBox)/2.0 - viaEdgeCenter
                    ) ; ** cond rexMatchp **
                 ) ; ** when xBias **
                 when(stringp(yBias) && !rexMatchp("[cC]enter" yBias) && rows > 1
                    cond(
                       (rexMatchp("[uU]pper" xBias)
                        yOffset = viaEdgeCenter - height(bBox)/2.0
                       (rexMatchp("[lL]ower" xBias)
                        yOffset = height(bBox)/2.0 - viaEdgeCenter
                 ) ; ** when yBias **
                 inst~>originOffset = xOffset:yOffset
              else
                 fprintf(stdout "(E) apcCreateContact:  Offset bias ignored, because viaEdgeCenter was not a number (xBias=%L, yBias=%L\n" xBias yBias)
              ) ; ** if numberp **
        else
           inst = dbCreateInst(cv master nil origin rotation)
           when(width
              inst~>l = width
           when(height
              inst~>w = height
           when(rows
              inst~>row = rows
           when(columns
              inst~>column = columns
           when(xPitch
              inst~>xPitch = xPitch
           when(yPitch
              inst~>yPitch = yPitch
           when(xBias
              inst~>xBias = xBias
           when(yBias
              inst~>yBias = yBias
        ) ; ** if isOA **
        inst
      ) ; ** let **
    ) ; ** procedure apcCreateContact **
  • Tsien
    Yes, that definitely helps.   Thanks for the reply.
     Its too bad that cadence doesn't improve the via accessibility through SKILL in OA.
     Tsien
