  3. SKILL mechanism to determine if CDBA or OA
  • Views 16664
TrevorB
TrevorB over 16 years ago
I would like to branch my pcell code based on whether the code is running inside IC6 (OA) or IC51 (CDBA).  What is the preferred, or recommended way of doing this.  I have thought of a few ways, but I want to use something, which will be supported for the lifetime of both platforms. ... Thanks!
  • dmay
    dmay over 16 years ago
    I use the following:
    procedure(mydbIsOA()
      prog(()
        if(getd('dbGetDatabaseType) && dbGetDatabaseType() == "OpenAccess" then
            return(t)
        else
            return(nil)
      ) ;let
    ) ;proc
    This works with very old Cadence versions that don't even have dbGetDatabaseType yet defined.
    We have a lot of skill code and getting all of our designs on 6.1.x will take quite some time (we don't have any parts there yet). I presented a paper at an Si2 conference about the effort we have been doing to try not to "branch" our code, but rather to make it compatible with both 5.1 and 6.1. The power point is available here: http://www.si2.org/events_dir/2006/oaconfspring2006/micron.pdf
    As you can see, I presented that in 2006 and we still haven't moved any parts to OA. We have wrapper functions in our Skill that allow us to easily test each new 6.1 release while only maintaining one stream of code.
    Derek
  • Yaosan
    Yaosan over 16 years ago
    Nice presentation Derek, thanks for sharing!
    So far I've been using my custom "isOA()" function, much like what Derek suggested. My function looks like this (a little more optimized):
    procedure( YYisOA()
        when( getd('dbGetDatabaseType) && dbGetDatabaseType() == "OpenAccess"
            t
  • TrevorB
    Yes, thanks for the tip and the presentation, Derek!
    Since we are offering condensed functions...
    procedure(isOA()
    If anybody else has a function that relies on a different mechanism, please let me know.  There's wisdom in a multitude of counselors.  :)
