  3. Get selected nets from Navigator in IC61
  • Subscribers 152
  • Views 15428
Yaosan
Yaosan over 16 years ago
Is there a way for me to get the selected nets in Navigator in IC61? For example when using the power routing feature, I need to select the nets I need from Navigator to add them to the power routing as nets to be routed.
I would like to use selected nets in Navigator as inputs for my function. Thanks!
  • Quek
    Quek over 16 years ago
    Hi Yaosan
    You can use hsmGetSelected as follows:
    hsmGetSelected(?type 'net)
    More details are available in $CDSHOME/doc/skcompref/skcompref.pdf
    It returns the names of the selected nets.
    Best regards
    Quek
  • Yaosan
    Hi Quek,
    That's exactly what I was looking for. Thank you!
    btw, the function is hsmGetSelectedSet()
