  3. Sorting Association Table by indexes names
  • Replies 7
  • Subscribers 150
  • Views 19471
ToMWUT
ToMWUT over 16 years ago
Hello All,
This time I’ve got a question about Association Tables – is there a simple way to sort elements in such table by indexes names, let us say alphabetically? I know that there is a simple way to sort elements in such table using sort function. But this approach is only valid, I think, when we concern comparing elements and not keys, or am I wrong?
Thanks ToM
    ToM,
    keys=sort(myTable->? 'alphalessp)
    Then you have a sorted list of keys that you can iterate over:
    foreach(key keys
    printf("%s %s\n" key myTable[key])
  • ToMWUT
    Thanks Andrew,
    I’ve got another question which is linked to the previous one. How can I compare in conditional statement two strings alphabetically? And as a result I would like to know which one should go first when we concern alphabetic order.
    ToM
  • ToMWUT
    I found solution by myself: alphalessp.
    Hi ToM,
    Sorry - didn't have a chance to reply sooner - I thought you might have spotted the alphalessp in my previous answer.
    Anyway, glad you've worked it out.
  • Eitan Shapira
    Eitan Shapira over 14 years ago
    Hi  Andrew,
    Is there an easy way to create a sort using two criterias ?
    Example:
     Sort this:
    PinA<15>
    PinB<15>
    PinB<11>
    PinA<14>
    PinA<11>
    PinB<11>
    PinB<12>
    PinA<13>
    PinB<14>
    PinA<12>
    To this:
    PinA<11>
    PinA<12>
    PinA<13>
    PinA<14>
    PinA<15>
    PinB<11>
    PinB<12>
    PinB<13>
    PinB<14>
    PinB<15>
    Eitan Shapira
    With this specific data you could do:
      pinNames=sort(pinNames 'alphalessp)
    but if you had PinA<2> in the list it would appear after PinA<15> which is probably not what you want. Instead you could use:
      pinNames=sort(pinNames lambda((a b) minusp(alphaNumCmp(a b))))
    The lambda is creating an anonymous function with two arguments which does a comparison. The second argument to sort can be any function of two arguments, and so you can make it have whatever criteria you like for comparing values.
  • Eitan Shapira
    Thank you so much!
